08-24-2021, 10:56 | #1 (permalink) |
Product Supporter Join Date: Feb 2008 Location: Jat-Chi-Bangladesh Age: 46
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | Universal Factory Format Error: DATA SND Timeout Error Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 90014A68433861503E03484184A11613 EMMC CSD: D02700328F5903FFFFFFFFEF8E400043 EMMC Manufacture : SKHYNIX , EMMC NAME: hC8aP> , HEX: 68433861503E , S/N: 484184A1 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 62838 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: hC8aP__484184A1_20210824_154032.extcsd EMMC Init completed. Scanning soft partitions Partition table not found Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 90014A68433861503E03484184A11613 EMMC CSD: D02700328F5903FFFFFFFFEF8E400043 EMMC Manufacture : SKHYNIX , EMMC NAME: hC8aP> , HEX: 68433861503E , S/N: 484184A1 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 62838 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: hC8aP__484184A1_20210824_154041.extcsd EMMC Init completed. Operation: Universal Factory Format Please, wait ... Error: DATA SND Timeout Error Error: DATA SND Timeout Error |
08-24-2021, 17:02 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | "Universal Factory Format" - it same as "Erase All ROM's" procedure, but more faster if some eMMC not support "Universal Factory Format", you can use "Erase All ROM's" I can't see any problem |
The Following User Says Thank You to layder For This Useful Post: |
