01-12-2015, 17:01 | #1 (permalink) |
Freak Poster Join Date: Oct 2010 Location: india
Member: 1417201 Status: Offline Sonork: 100.1626868 Thanks Meter: 32 | s7580 efs repair error here is info For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. - EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL Check security...OK Initialising: SAMSUNG GT-S7580 Config ver.:1.00 I/O Level set to : 2200 mV Box S/N: 0F0F030137747A01 ,FW Ver.: 01.51 Connecting to Target... JTAG device: BCM21664 CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4 CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9 Halting CPU... Target Not Examined |
01-12-2015, 17:04 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
check RST pin, try keep power pressed button while booting. check other pins. | |
01-12-2015, 17:11 | #3 (permalink) |
Member: 1417201 Status: Offline Sonork: 100.1626868 Thanks Meter: 32 | now while press power key here is info For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. - EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL Check security...OK Initialising: SAMSUNG GT-S7580 Config ver.:1.00 I/O Level set to : 2200 mV Box S/N: 0F0F030137747A01 ,FW Ver.: 01.51 Connecting to Target... JTAG device: BCM21664 CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4 CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9 Halting CPU... Init target ... Starting target communication... Detecting emmc memory parameters of bank (0) ... Error: Memory write access failed. DCC Loader init Failed! BUG: emmc unknown controller initialization failure |
01-12-2015, 19:32 | #4 (permalink) | |
01-07-2018, 20:45 | #8 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2797335 Status: Offline Thanks Meter: 0 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' if needed. Operation: Reboot to Download Selected model: GT-S7580 Software version: 28.2 Waiting ADB device... OK Reading phone info... Model: GT-S7580 Android version: 4.2.2 Product code: Phone version: S7580XXUBOA1 PDA version: S7580XXUBOA1 CSC version: S7580OXXBOA1 CSC country code: Germany CSC sales code: DBT HW version: Phone S/N: 00000000000 Modem board: RF cal date: IMEI: 353738062531007 Rebooting to download... OK Done with Samsung Tool PRO v.28.2 |
