Using Easy Jtag for Data Recovery Hi I thinking on purchase Easy Jtag just for data recovery work, mainly from dead phones. I don't need to repair or unlock phones. Is it the ideal tool? Can I get the data (photos, videos, for instance) out of a dead phone PCB? Will I have any type of encryption problem or the data reads directly? Do you have any videos/tutorials for this? Will it also work on tablets? What do you suggest? Thank You |
You can use "EasyJTAG eMMC plus" tool and ""Emmc FileManger Addon" to extract dato from unencrypted disks from eMMC (ext, fat, ntfs) Android 7 and 8 used encrypted userdata by default |
Hello. There is no way to extract the data in Android 7 and Android 8 ?, not even with another box like ufi box? |
The problem is that encryption... Is there any solution? What about tablets? Can it work with them too? Thank You |
eMMC File Manager screenshot: http://i97.fastpic.ru/big/2017/1129/...e3819e3e52.png work with tablet eMMC at socket via EasyJtag Box Plus |
Enviado desde mi HTC One_M8 mediante Tapatalk |
Android 7 and 8 crypt data patition by default. |
Well, 90% of the android market phones still work under version 7 or 8. So the chance of getting a phone decrypted is still high I think. |
1 Attachment(s) xiaomi note 4 android 7.0 userdata not open it is file binary i use easy 2.061 version new have extract ????? |
if userdata crypted - you see it |
eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017) Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.22177) Mount [dsp] successfully PartType: LINUX Mount [system] successfully PartType: LINUX Mount [cache] successfully PartType: LINUX Mount [persist] successfully PartType: LINUX Mount [misc] successfully PartType: LINUX Mount [cust] successfully PartType: LINUX Mount [userdata] SKIPPED PartType: Full Disk Encryption <-> not ok |
Get firmware version Brand = xiaomi Manufacturer = Xiaomi Model = Redmi Note 4 Phone platform = msm8953 CPU Abi = arm64-v8a Android release = 7.0 Firmware version = AL1512-mido-build-20171028011511 Firmware date = Sat Oct 28 01:15:09 WIB 2017 |
Full Disk Encryption - How to fix? I need recove data but faile..can you help me here log : eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017) Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.17686) Looking for EasyJTAG box... EasyJTAG API ver. 2022 EasyJTAG Box Serial = Card Serial = EasyJTAG Box Firmware = 1.62 Changelog: 12.12.2017 (ver 1.4.9.0) Fix: Bugs that have been found through your crash report Fix: RandomVerify function Fix: Creation of GPT for Samsung (write by vendor) Fix: Failed to mount large Fat partitions (explorer) Fix: Extraction from contact2.db (explorer) Fix: Error in the "build.prop" parser Fix: CID Parser Add: Support for EasyJtag Plus Box Add: Path for TempDir and InitialDir (option in settings) Add: Unpack Lenovo QSB (utilities) Add: Selecting a PIT file from CSC (write by vendor Samsung) Add: Detect for encrypted dumps from GPG Box Add: Detect for FullDiskEncryption Partition (explorer) Add: LinearVerify of the Partition (read by vendor) Add: Information base about emmc compatibility (thanks to phonemicrodb) Add: Resizing the window (for small screen resolutions) Add: Converting large partitions in SparseImage when reading by vendor (option in settings) Add: Mounting SparseImage (explorer) Add: Automatic backup of the EFS partition for Samsung (read by vendor) Add: Formatting of EFS partition for Samsung on request (write by vendor) Scan from image: userdata.bin Vendor: Samsung Searching GPT ... GPT header is not found Searching PIT ... PIT not found Partition table not found Scan done Setting frequence to 14 Mhz CMD Pullup Level: 2784 mV CMD Active Level: 2722 mV EMMC Device Information : EMMC CID: 150100514E3136424200600ED2AB242C EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SAMSUNG , EMMC NAME: QN16BB , EMMC NAME (HEX): 514E31364242 , S/N: 600ED2AB , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 2/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16BB_600ED2AB_20180204_151830.extcsd EMMC Init completed. Scan from: QN16BB Vendor: Samsung Searching GPT ... GPT header is found and is valid GPT header successfully parsed Scan done Mount [efs] successfully PartType: LINUX Mount [nvdata] successfully PartType: LINUX Mount [protect_f] successfully PartType: LINUX Mount [protect_s] successfully PartType: LINUX Mount [system] successfully PartType: LINUX Mount [cache] successfully PartType: LINUX Mount [preload] successfully PartType: LINUX Mount [userdata] SKIPPED PartType: Full Disk Encryption |
