vivo y11 (1906) dead boot repair done Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Box Voltage set to: 2800 mV Scanner Thread Created.. Config: 1011111111101111 Setup HiPower CLK: OFF Connecting To EasyJtag Plus Box: 2800mV/21MHz/8BIT EasyJtag Plus Box Found! Result: 0/OK EasyJtag Plus S/N: 16F03C9E6AE1BE10 EasyJtag Plus Box FirmWare: 2.53 Box Bus Width = 8 BIT Box Hardware = EasyJtag 2nd Generation Search EMMC Chip... Testing Box Interface PIN CLK : 1652 mV -> Pin OK PIN CMD : 1662 mV -> Pin OK PIN DAT0: 1666 mV -> Pin OK PIN DAT1: 1660 mV -> Pin OK PIN DAT2: 1663 mV -> Pin OK PIN DAT3: 1661 mV -> Pin OK PIN DAT4: 1662 mV -> Pin OK PIN DAT5: 1663 mV -> Pin OK PIN DAT6: 1665 mV -> Pin OK PIN DAT7: 1665 mV -> Pin OK Test End EMMC Chip Found! 0/OK EMMC CID: 150100474436424D420133486A83B66D EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC VENDOR: SAMSUNG EMMC NAME: GD6BMB EMMC SERIAL: 33486A83 EMMC REVISION: 01 EMMC ROM1 Size: 61071360 Block(s)/29820 MB EMMC ROM2/3 Size: 8192 Block(s)/4096 KB EMMC RPMB Size: 8192 Block(s)/4096 KB EMMC RPMB Counter: 3036 EMMC RPMB Answer: 0/OK Switch To ROM1 Part: 0/OK EMMC REV: 1.8 (for MMC v5.1) EMMC VER: MMC 5.1 EMMC DEV Life Time: 0x01 -> Normal EMMC MLC Life Time: 0x02 -> 10% - 20% Life Time Used EMMC SLC Life Time: 0x02 -> 10% - 20% Life Time Used EMMC Boot Config: 0x38/0x00/0x01 ExtCSD Automatically Saved.. Scanning Data From EMMC. Please wait.. Scanning GUID Partition Table from ROM1 GUID Partition Table is Found. Max Parts: 60 GPT: GPT [000000000000 - 000000004400] Size: 17.00 KB GPT: MODEM [000001000000 - 000008000000] Size: 128.00 MB GPT: FSC [000009000000 - 000000000400] Size: 1.00 KB GPT: SSD [000009001000 - 000000002000] Size: 8.00 KB GPT: SBL1 [000009003000 - 000000080000] Size: 512.00 KB GPT: SBL1BAK [000009083000 - 000000080000] Size: 512.00 KB GPT: RPM [000009103000 - 000000080000] Size: 512.00 KB GPT: RPMBAK [000009183000 - 000000080000] Size: 512.00 KB GPT: TZ [000009203000 - 000000200000] Size: 2.00 MB GPT: TZBAK [000009403000 - 000000200000] Size: 2.00 MB GPT: DEVCFG [000009603000 - 000000040000] Size: 256.00 KB GPT: DEVCFGBAK [000009643000 - 000000040000] Size: 256.00 KB GPT: DSP [000009683000 - 000001000000] Size: 16.00 MB GPT: DSPBAK [00000A683000 - 000001000000] Size: 16.00 MB GPT: MODEMST1 [00000B683000 - 000000280000] Size: 2.50 MB GPT: MODEMST2 [00000B903000 - 000000280000] Size: 2.50 MB GPT: DDR [00000C000000 - 000000008000] Size: 32.00 KB GPT: FSG [00000C008000 - 000000280000] Size: 2.50 MB GPT: SEC [00000C288000 - 000000004000] Size: 16.00 KB GPT: SPLASH [00000D000000 - 000000B00000] Size: 11.00 MB GPT: ABOOT [00000E000000 - 000001000000] Size: 16.00 MB GPT: ABOOTBAK [00000F000000 - 000001000000] Size: 16.00 MB GPT: DTBO [000010000000 - 000000800000] Size: 8.00 MB GPT: DTBOBAK [000010800000 - 000000800000] Size: 8.00 MB GPT: VBMETA [000011000000 - 000000010000] Size: 64.00 KB GPT: VBMETABAK [000011010000 - 000000010000] Size: 64.00 KB GPT: BOOT [000011020000 - 000004000000] Size: 64.00 MB GPT: RECOVERY [000015020000 - 000004000000] Size: 64.00 MB GPT: DEVINFO [000019020000 - 000001000000] Size: 16.00 MB GPT: SYSTEM [00001A020000 - 000100000000] Size: 4.00 GB GPT: VENDOR [00011A020000 - 000040000000] Size: 1.00 GB GPT: CACHE [00015B000000 - 000010000000] Size: 256.00 MB GPT: PERSIST [00016B000000 - 000002000000] Size: 32.00 MB GPT: MISC [00016D000000 - 000000100000] Size: 1.00 MB GPT: KEYSTORE [00016D100000 - 000000080000] Size: 512.00 KB GPT: CONFIG [00016D180000 - 000000008000] Size: 32.00 KB GPT: OEM [00016D188000 - 000004000000] Size: 64.00 MB GPT: LIMITS [000172000000 - 000000008000] Size: 32.00 KB GPT: MOTA [000173000000 - 000000080000] Size: 512.00 KB GPT: DIP [000173080000 - 000000100000] Size: 1.00 MB GPT: MDTP [000173180000 - 000002000000] Size: 32.00 MB GPT: MDTPBAK [000175180000 - 000002000000] Size: 32.00 MB GPT: SYSCFG [000177180000 - 000000080000] Size: 512.00 KB GPT: MCFG [000177200000 - 000000400000] Size: 4.00 MB GPT: CMNLIB [000178000000 - 000000100000] Size: 1.00 MB GPT: CMNLIBBAK [000178100000 - 000000100000] Size: 1.00 MB GPT: CMNLIB64 [000178200000 - 000000100000] Size: 1.00 MB GPT: CMNLIB64BAK [000178300000 - 000000100000] Size: 1.00 MB GPT: KEYMASTER [000178400000 - 000000100000] Size: 1.00 MB GPT: KEYMASTERBAK [000178500000 - 000000100000] Size: 1.00 MB GPT: SURVIVAL [000178600000 - 000004000000] Size: 64.00 MB GPT: APDP [00017D000000 - 000000040000] Size: 256.00 KB GPT: MSADP [00017D040000 - 000000040000] Size: 256.00 KB GPT: DPO [00017D080000 - 000000002000] Size: 8.00 KB GPT: LOGDUMP [00017D082000 - 000004000000] Size: 64.00 MB GPT: APANIC [000181082000 - 000000A00000] Size: 10.00 MB GPT: BACKUP [000181A82000 - 000000A00000] Size: 10.00 MB GPT: SEED [000182482000 - 000000400000] Size: 4.00 MB GPT: RESERVED [000182882000 - 000000A00000] Size: 10.00 MB GPT: USERDATA [000183282000 - 0005C4979E00] Size: 23.07 GB GPT: BACKUP_GPT [000747BFBE00 - 000000004200] Size: 16.50 KB Reading Table Completed Scanning GUID Partition Table from ROM2 GPT Signature Not Found. Break.. Scanning GUID Partition Table from ROM3 GPT Signature Not Found. Break.. Partition #5 mount as [/MODEM] -> 128.00 MB Partition #16 mount as [/dev_16] -> 16.00 MB Partition #17 mount as [/dev_17] -> 16.00 MB Partition #33 mount as [/dev_33] -> 4.00 GB Partition #34 mount as [/dev_34] -> 1.00 GB Partition #35 mount as [/cache] -> 256.00 MB Partition #36 mount as [/mnt/vendor/persist] -> 32.00 MB Partition #40 mount as [/dev_40] -> 64.00 MB ================================= Warning! Partition #63 -> 'USERDATA' is ENCRYPTED! ================================= EmptyCheck: EMPTY -> #22 - [SPLASH] EMPTY -> #36 - [MISC] EMPTY -> #37 - [KEYSTORE] EMPTY -> #40 - [LIMITS] EMPTY -> #41 - [MOTA] EMPTY -> #42 - [DIP] EMPTY -> #45 - [SYSCFG] EMPTY -> #46 - [MCFG] EMPTY -> #54 - [APDP] EMPTY -> #55 - [MSADP] EMPTY -> #56 - [DPO] EMPTY -> #57 - [LOGDUMP] EMPTY -> #58 - [APANIC] EMPTY -> #60 - [SEED] EMPTY -> #61 - [RESERVED] EmptyCheck: Done ================================= Warning! Device Blocked by FRP For Reset FRP Try to Tools Tab Press Reset FRP Button Partition #39 -> CONFIG ================================= Android Info: Brand = vivo Vendor = vivo Device = PD1930F_EX Model = vivo 1906 Product = msm8937_64 CPU ABI = arm64-v8a Android Version = 9 Firm Version = PKQ1.190616.001 release-keys Inc. Version = compiler10121746 Firm Date = Mon Oct 12 17:45:52 CST 2020 Security Patch = 2020-09-01 Android Info: Platform = msm8937 Scanner Thread Terminated Elapsed: 00:00:04:606 Found 64 Partition(s).. Scan Done. Init Main Engine... Resetting EasyJtag Box. Wait.. Reader Engine Initialized.. 0/OK Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Bus Mode: 8BIT Operation Done: [Init Engine], Elapsed: 00:00:01:813 :cool::cool::cool: |
is this chip off or isp do you have any dumpfile thanks |
need vivo 1906 dump file... plz help.......??? |
i have full dump for this model .. msg me if youstill want.. |
pls..share dump file...pls... |
please share dump file link please brothers....... |
