Old 12-18-2022, 15:22   #1 (permalink)
MUNEEB_AKHTAR_RAZA's Avatar
Member: 152244
Sonork: 100.1591179
Thanks Meter: 162
Vivo Y11 Dead Partitions table not found.
Hello,
I got vivo y11 1906 in dead state.Somebody formatted this phone and after that phone got dead.Now whenever i connect it with easy jtag i got this..
Setting interface to EasyJtag2/ISP_HiPower
Setting bus width to 1 Bit
HiPower mode is ON
Setting frequence to 24 MHz
CMD Pullup Level: 1816 mV
CMD Active Level: 1864 mV
EMMC Device Information :
EMMC CID: 150100474436424D4201CE0707EEB687
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture : SAMSUNG , EMMC NAME: GD6BMB , HEX: 474436424D42 , S/N: CE0707EE , rev. 0x01
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2019
   EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
   EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 113843 , Response: Not Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: GD6BMB_CE0707EE_20221218_173101.extcsd
EMMC Init completed.
Scanning soft partitions
Partition table not found
Get firmware version
Firmware info not found
I cant be able to find any tested dump file i tried with different dump files and get this
Operation: Writing all eMMC Regions...
The file is too large for the ROM3. The size has been corrected
Operation: Writing BootConfig ...
Reg: 179  Value: 0x38
Reg: 177  Value: 0x00
Reg: 162  Value: 0x01
Done
Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000
Filename: boot2.bin
eMMC switching to ROM2
Writing partition...
Error writing at address: 000000000000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1
Error writing at address: 000000000000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #2
Error writing at address: 000000000000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #3
Too many errors. Writing has been stopped
Now can anyone provide me the solution please?
Regards
Page generated in 0.11126 seconds with 8 queries
