Wildfire S Easy Repair? [New RCP inside] Hi ! I want to restore Wildfire S. BBut getting an error: Connecting to Target... JTAG device: MSM7227T CPU IDCODE : 0x203C10E1 Mfg.: 0x070, Part: 0x03c1, Ver.: 0x2 CPU Manufacturer: QUALCOMM , CPU Name: MSM7227T Halting CPU... Initialize hardware... Starting target communication... Detecting nand memory parameters ... NAND flash device ID:00AD:00BC 'NAND 512MB 1.8V 16-bit (Hynix)' found NAND geometry: Blocks:00001000, Page size:2048 bytes , Block size:64 pages Restoring MIBIB couldn't open MIBIB.bin failed to open 'MIBIB.bin' for read access Tried on two phones, one of them known-good. In what could be the reason? |
I confirm this, repair does not work, I have the same log |
please post full log. we will test. i have this phone in hands. WildFire S resurecto V2 file - try this . CLICK |
The second file is the same. log with the first file: Using EasyRepair Mode... Checking repair data... EasyJtag Suite ver.: 1.0.61.1 started. Operating system ver.: Windows XP (build 2600, Service Pack 3). For support and updates visit EasyJtag , just better ? - New powerful JTAG unbrick device. Initialising: HTC Wildfire S Config ver.:1.00 I/O Level set to : 2600 mV Box S/N: 0E0EFC12FA73B7DD ,FW Ver.: 01.47 Connecting to Target... JTAG device: MSM7227T CPU IDCODE : 0x203C10E1 Mfg.: 0x070, Part: 0x03c1, Ver.: 0x2 CPU Manufacturer: QUALCOMM , CPU Name: MSM7227T Halting CPU... Initialize hardware... Starting target communication... Detecting nand memory parameters ... NAND flash device ID:00AD:00BC 'NAND 512MB 1.8V 16-bit (Hynix)' found NAND geometry: Blocks:00001000, Page size:2048 bytes , Block size:64 pages Restoring MIBIB couldn't open MIBIB.bin failed to open 'MIBIB.bin' for read access The second file: Easy-Repair file load OK! Using EasyRepair Mode... Checking repair data... EasyJtag Suite ver.: 1.0.61.1 started. Operating system ver.: Windows XP (build 2600, Service Pack 3). For support and updates visit EasyJtag , just better ? - New powerful JTAG unbrick device. Initialising: HTC Wildfire S Config ver.:1.00 I/O Level set to : 2600 mV Box S/N: 0E0EFC12FA73B7DD ,FW Ver.: 01.47 Connecting to Target... JTAG device: MSM7227T CPU IDCODE : 0x203C10E1 Mfg.: 0x070, Part: 0x03c1, Ver.: 0x2 CPU Manufacturer: QUALCOMM , CPU Name: MSM7227T Halting CPU... Initialize hardware... Starting target communication... Detecting nand memory parameters ... NAND flash device ID:00AD:00BC 'NAND 512MB 1.8V 16-bit (Hynix)' found NAND geometry: Blocks:00001000, Page size:2048 bytes , Block size:64 pages Restoring MIBIB couldn't open MIBIB.bin failed to open 'MIBIB.bin' for read access |
i will check now again. may be problem becouse used capital characters inside rpc file. In 1-2h i will upload v.1.02 rcp file. |
please try new rcp here |
This file is a good (HTC_WILDFIRE_S_V1.02): Connecting to Target... JTAG device: MSM7227T CPU IDCODE : 0x203C10E1 Mfg.: 0x070, Part: 0x03c1, Ver.: 0x2 CPU Manufacturer: QUALCOMM , CPU Name: MSM7227T Halting CPU... Initialize hardware... Starting target communication... Detecting nand memory parameters ... NAND flash device ID:00AD:00BC 'NAND 512MB 1.8V 16-bit (Hynix)' found NAND geometry: Blocks:00001000, Page size:2048 bytes , Block size:64 pages Restoring MIBIB NAND Write OK! Elapsed time: 12.109375s (109.006 KiB/s) Restoring QCSBL NAND Write OK! Elapsed time: 4.828125s (109.359 KiB/s) Restoring OEMSBL1 NAND Write OK! Elapsed time: 7.046875s (112.390 KiB/s) Restoring OEMSBL2 NAND Write OK! Elapsed time: 7.046875s (112.390 KiB/s) Restoring HTC NAND Write OK! Elapsed time: 19.343750s (109.183 KiB/s) Restoring AMSS NAND Write OK! Elapsed time: 232.296875s (109.102 KiB/s) Restoring APPSBL NAND Write OK! Elapsed time: 7.046875s (112.390 KiB/s) Restoring MISC_MFG NAND Write OK! Elapsed time: 2.359375s (111.894 KiB/s) Restoring WLAN NAND Write OK! Elapsed time: 2.421875s (109.006 KiB/s) All Done. |
