GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Easy-Jtag / Easy-Jtag Plus (https://forum.gsmhosting.com/vbb/f672/)
-   -   Windows 10 64 bit box driver Solution 100% (https://forum.gsmhosting.com/vbb/f672/windows-10-64-bit-box-driver-solution-100-a-2927941/)
NoName® 08-07-2015 14:37
Important notice for Windows 10 Users
3 Attachment(s)
Hello , all Users of new Microsoft OS. We have tested our box compliance via testing in the hardware in different modes. And seems everything are OK
http://forum.gsmhosting.com/vbb/atta...1&d=1438984619
Note. If your EasyJTAG suite ask for driver update reinstall EasyJTAG driver again by hands because windows Native PNP driver are did not work!
Comport in Device Manager should be like in picture:
http://forum.gsmhosting.com/vbb/atta...1&d=1438954566
If you still experience any problem installing driver - then :
Disabling Driver Signature Enforcement In Windows 8 Permanently
Step 1. Open the Windows command promt as “Run as Administrator”.
Step 2. Run “bcdedit -set loadoptions DISABLE_INTEGRITY_CHECKS” (without the “”).
Step 3. To finalize the process run “bcdedit -set TESTSIGNING ON” (without the “”).
Step 4. Reboot and you’re done. (source)
If you get "The value is protected by secure boot policy and cannot be modified or deleted"
Step 1. Open Charms bar (Win+C)-> Settings -> Change PC Settings (click on it)
Step 2. In PC Settings go to General->Advanced Start Up (at the far bottom)
Step 3. Select Troubleshoot -> Advanced Options -> UEFI Firmware Settings-> Restart
Once the computer restarts, it will go to the BIOS.
In some laptops on the SECURITY Tab you will not able to change the settings for Security Boot Policy. In that case
you have to set a SUPERVISOR password and then you will able to [DISABLE] the Security Boot Policy.
http://forum.gsmhosting.com/vbb/atta...1&d=1443037019http://forum.gsmhosting.com/vbb/atta...1&d=1443037019
Now, Exit and Save Changes.
Suraj#1 08-18-2015 00:25
Hi NoName,
which version of win10 ? 32 or 64 ? Unsigned drivers is OK ?
djawir 09-23-2015 18:22
win 10 64 bit cant install box driver
NoName® 09-23-2015 20:39
Read first post and. It has been updated!
dark140 10-01-2015 18:50
He works well with me
DataMunched 04-21-2016 11:09
You can disable driver signing in Windows 10 by pressing shift and restart. It takes you into a menu which where you can disable it.
Will this work instead of above?
erikcell 08-09-2016 18:59
z3easy no recnoce driver en windows 10 64 bit
runs on Windows 10 bit 64 friends
allumts 08-09-2016 22:32
Here Easy Procedure w/o enter in Bios and can use only when you need of "Disable Signature for one time"
how-to-disable-driver-signature-verification-on-64-bit-windows-10-so-that-you-can-install-unsigned-drivers
NOTE: when have installed Unsigned drivers at restart turn back with "Signature Drivers Enabled" BUT Not lost the Installed Drivers, tested for many Box/Dongle and all Full working
allumts
grantgoskusky 09-07-2016 22:56
Very useful, thanks!
kd2telepoint 10-05-2016 06:31
Disabling Driver Signature Enforcement In Windows 7 Permanently
brackz 10-13-2016 21:55
comes in very handy and i finally got it figured out
amin_aghasi 10-14-2016 22:49
It works well with me
trebrob 12-09-2016 02:29
works for me on 64 bit windows 10
yales666 12-18-2016 01:10
this work for me, and can solve many problem
osama.90 12-27-2016 03:01
work with meeeeeee win 10 box.s
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.11856 seconds with 6 queries
