Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,174 | Important notice for Windows 10 Users Note. If your EasyJTAG suite ask for driver update reinstall EasyJTAG driver again by hands because windows Native PNP driver are did not work! Comport in Device Manager should be like in picture: If you still experience any problem installing driver - then : Disabling Driver Signature Enforcement In Windows 8 Permanently Step 1. Open the Windows command promt as “Run as Administrator”. Step 2. Run “bcdedit -set loadoptions DISABLE_INTEGRITY_CHECKS” (without the “”). Step 3. To finalize the process run “bcdedit -set TESTSIGNING ON” (without the “”). Step 4. Reboot and you’re done. (source) If you get "The value is protected by secure boot policy and cannot be modified or deleted" Step 1. Open Charms bar (Win+C)-> Settings -> Change PC Settings (click on it) Step 2. In PC Settings go to General->Advanced Start Up (at the far bottom) Step 3. Select Troubleshoot -> Advanced Options -> UEFI Firmware Settings-> Restart Once the computer restarts, it will go to the BIOS. In some laptops on the SECURITY Tab you will not able to change the settings for Security Boot Policy. In that case you have to set a SUPERVISOR password and then you will able to [DISABLE] the Security Boot Policy. Now, Exit and Save Changes. Last edited by NoName®; 09-23-2015 at 21:04. |
The Following 13 Users Say Thank You to NoName® For This Useful Post: |
![]() | #6 (permalink) |
Junior Member ![]() Join Date: Nov 2015
Member: 2491556 Status: Offline Thanks Meter: 2 | You can disable driver signing in Windows 10 by pressing shift and restart. It takes you into a menu which where you can disable it. Will this work instead of above? |
The Following User Says Thank You to DataMunched For This Useful Post: |
![]() | #8 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Apr 2011 Age: 55
Member: 1564612 Status: Offline Thanks Meter: 11,915 ![]() | Here Easy Procedure w/o enter in Bios and can use only when you need of "Disable Signature for one time" how-to-disable-driver-signature-verification-on-64-bit-windows-10-so-that-you-can-install-unsigned-drivers NOTE: when have installed Unsigned drivers at restart turn back with "Signature Drivers Enabled" BUT Not lost the Installed Drivers, tested for many Box/Dongle and all Full working BR allumts |
The Following 4 Users Say Thank You to allumts For This Useful Post: |
