01-23-2021, 11:27 | #1 (permalink) |
Junior Member Join Date: Jan 2021 Location: ALGERIA Age: 33
Member: 2978114 Status: Offline Thanks Meter: 0 | XIAOMI Redmi note 8t no boot, vibrate only Reason: water damege Work: cleaned, tested for short, resoldering. State: when power button pushed it vibrates only. More info at request. I was able to comunicate with the emmc, but i get the message "firmware info not found" when i try to get the firmware info. Any solution would be appreciated, i will post the logs in few hours when i get to shop. |
01-25-2021, 03:11 | #3 (permalink) |
Insane Poster Join Date: Sep 2018 Location: India
Member: 2868909 Status: Offline Thanks Meter: 36 | Hello mate , it would be better if you post logs. Does your emmc still have valid partitions ? if it has you can try flashing stock firmware from miui website but also keep i mind some device shows firmware info not found even f theres no soft issues and phones fully functional , I woukd recommend you to cross check for hardware fault again (especially at power section ) before trying anything in software coz the issue came due to water damage . |
The Following User Says Thank You to johnnybravo9889 For This Useful Post: |
01-27-2021, 13:31 | #5 (permalink) | |
Member: 2978114 Status: Offline Thanks Meter: 0 | Quote:
after cleaning an resoldering same situation... when i put it on the power supply and push the power button, it goes from 0amps to 0.12 and down again, i also tried to write the boot img from a firmware i downloaded and i kept receiving DATA SND CRC error, i tried many times, some times it starts to write and stop before it ends, most of the times it gives this error at random places, i also tried writing recovery, and system, always get the same error at random points, and i was able to backup without errors. what i did until now is: backedup userdata, factory format, erase emmc, and i am waiting for emmc to finish erasing it looks slow, max speed is 7800KB/S, what do i have to do next? | |
01-27-2021, 18:45 | #6 (permalink) |
Member: 2978114 Status: Offline Thanks Meter: 0 | now i was able to overcome the data snd crc error by increasing the voltage to 3.0V and freq to 4MHZ , now it is writing normally, but the speed is 440KB/s, is it normal? |
01-28-2021, 13:06 | #9 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
About wire lenght: I already wrote many times about ISP connection: https://forum.gsmhosting.com/vbb/f67...-1mhz-2915742/ https://forum.gsmhosting.com/vbb/f67.../#post14270282 Last edited by layder; 01-28-2021 at 14:53. | |
The Following User Says Thank You to layder For This Useful Post: |
01-28-2021, 17:33 | #10 (permalink) |
Member: 2978114 Status: Offline Thanks Meter: 0 | thanks, i will see what i can learn, i will read your posts, and if you know anything else useful please send me(text or video), this is the first phone i am working on with easyjtag, i was able to remove FRP from a oppo A1K but that was not as complicated as this one. |
01-31-2021, 14:15 | #11 (permalink) |
Member: 2978114 Status: Offline Thanks Meter: 0 | eMMC are unusable. Error writing at address: 000000000000 , error: -8 , DATA SND CRC Error(Small ROM Size, maybe) ... Retry #4 Can't init device. Reason: CMD Timeout Error now i am not even able to write to this phone, after i successfully revived it with willow global image v11.0.5.0 PCXMIXM GLOBAL, the owner asked for v12, so i formated again, and now i cannot write, i tried all the combinations of voltages and frequances, i resoldered many times, replaced the wires, all 7cm, gnd wire is thicker, i tried two different computers, one is win 10 usb 3.0 and the other is win 7 usb 2.0, with different cables, with battery and with usb cable, hipower mode on and off, i even tried the V11.0.5 that worked previously and it did not work this time, what am i missing here? logs attached. |
01-31-2021, 15:39 | #13 (permalink) | |
01-31-2021, 19:14 | #14 (permalink) |
Member: 2978114 Status: Offline Thanks Meter: 0 | i got error HW parts check FAIL when i click test settings Code: Checking security ... Running:JEDEC: Partitions config burn... Z3X EasyJtag Software ver. 3.7.0.20 Skip loading eMMC Addon Firmware CMD Pullup Level:364 mV CMD Active Level:891 mV Box IO Level:1800 mV CLK Rate:4000 kHz GPP Partition Size Multiplier: 800000, 8192 Kb, 8Mb Partition configuration: No enhanced user data area User partition write reliability: off No GP1 partition GP1 write reliability: on No GP2 partition GP2 write reliability: off No GP3 partition GP3 write reliability: off No GP4 partition GP4 write reliability: off All GP Partitions are 0 set size of at least one GP Partition HW Parts Check Fail. |
