08-08-2017, 07:18 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Buenos Aires, Argentina
Member: 331917 Status: Offline Thanks Meter: 214 | Second xt1021 on 9008 Code: EasyJtag Suite Classic ver.: 2.6.0.1 / wxWidgets 3.1.0-W-U started. OS ver.: Windows XP (build 2600, Service Pack 3). Admin rights FAIL undefined Android Explorer ver.: 1.0.0.23 eMMC ODIN ver.: 1.0.11.2 Successfully connected to box on COM8 Box S/N: ***************, ,FW Ver.: 01.60 Box Working Mode: JTAG Box. Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : *** , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: ****, ,FW Ver.: 01.60 CMD Pullup Level:2062 mV CMD Active Level:2371 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A4834473164040502A122AA415C EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 04/2014 Rev.0x5 EMMC NAME: H4G1d , S/N: 44114602 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G1d _ 44114602_20170808_0305.extcsd Done. Checking NAND Image : C:\Documents and Settings\NoneHp\Escritorio\MOTOROLA_XT1021\ext_csd.bin File successefuly loaded! Checking NAND Image : C:\Documents and Settings\NoneHp\Escritorio\MOTOROLA_XT1021\boot2.bin File successefuly loaded! Found EXT CSD and automatically selected. Checking NAND Image : C:\Documents and Settings\NoneHp\Escritorio\MOTOROLA_XT1021\boot1.bin File successefuly loaded! Found EXT CSD and automatically selected. Checking NAND Image : C:\Documents and Settings\NoneHp\Escritorio\MOTOROLA_XT1021\userarea256_MiB.bin Autodetected RAW data Warning! Disk size is smaller than the main header indicates! Loading Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Partition info successfully found Linux partitions is not found in image... File successefuly loaded! Found EXT CSD and automatically selected. Real (Hardware) Disk/Image size: 80000 sectors 256.0 MiB Soft (Partitioned) Disk/Image size: 74BFBC sectors 3.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 7651294 Processing file...C:\Documents and Settings\NoneHp\Escritorio\MOTOROLA_XT1021\ext_csd.bin Processing file...C:\Documents and Settings\NoneHp\Escritorio\MOTOROLA_XT1021\userarea256_MiB.bin Processing file...C:\Documents and Settings\NoneHp\Escritorio\MOTOROLA_XT1021\boot1.bin Processing file...C:\Documents and Settings\NoneHp\Escritorio\MOTOROLA_XT1021\boot2.bin Running:Repair extCSD... Z3X EasyJtag Software ver. 2.6.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2062 mV CMD Active Level:2371 mV Box IO Level:2800 mV CLK Rate:14000 khz ------------Parsing extCSD------------ ============================================= Extended CSD rev 1.6 (MMC 4.5) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x03]: implementation based on CMD12 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3c] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x20] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x03] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x03] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x19] Power off notification [POWER_OFF_LONG_TIME: 0xff] Cache Size [CACHE_SIZE] is 256 KiB Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x19] Power off notification [POWER_OFF_LONG_TIME: 0xff] Cache Size [CACHE_SIZE] is 256 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x32] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x04] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x09] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x09] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x03] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x08] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x08] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x01] Sleep current (VCC) [S_C_VCC: 0x06] Sleep current (VCCQ) [S_C_VCCQ: 0x0a] Sleep/awake timeout [S_A_TIMEOUT: 0x10] Sector Count [SEC_COUNT: 0x0074c000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x08] [MIN_PERF_R_8_52: 0x08] [MIN_PERF_W_8_26_4_52: 0x08] [MIN_PERF_R_8_26_4_52: 0x08] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x08] [MIN_PERF_R_4_26: 0x08] Power classes registers: [PWR_CL_26_360: 0x02] [PWR_CL_52_360: 0x02] [PWR_CL_26_195: 0x05] [PWR_CL_52_195: 0x05] Partition switching timing [PARTITION_SWITCH_TIME: 0x03] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0a] I/O Driver Strength [DRIVER_STRENGTH: 0x0f] Card Type [CARD_TYPE: 0x17] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x38] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x10 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x08 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0001d3 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 ------------Done parsing------------ Writing as extCSD 4.5 Done. Z3X EasyJtag Software ver. 2.6.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2062 mV CMD Active Level:2371 mV Input file : C:\Documents and Settings\NoneHp\Escritorio\MOTOROLA_XT1021\userarea256_MiB.bin Writing 0010000000 bytes to 0000000000... ROM1 (USER ROM) Full Verify Enabled! Write Block Failed, Reason: Write Block Verify Error Done. Done with error(s) Z3X EasyJtag Software ver. 2.6.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2062 mV CMD Active Level:2371 mV Input file : C:\Documents and Settings\NoneHp\Escritorio\MOTOROLA_XT1021\boot1.bin Writing 0000100000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Full Verify Enabled! Done. Write Speed: 737 kB/s Z3X EasyJtag Software ver. 2.6.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2062 mV CMD Active Level:2371 mV Input file : C:\Documents and Settings\NoneHp\Escritorio\MOTOROLA_XT1021\boot2.bin Writing 0000100000 bytes to 0000000000 ...ROM3 (BOOT2 ROM) Full Verify Enabled! Done. Write Speed: 677 kB/s I try to write, and it gives error, so, I erased rom1, and it was erased ok, so, I assume, emmc can be written (delete is write 00 if I am not wrong) I readed after erase, and it was all 00 ideas please? thanks |
