Z3x UFS/BGA 254 and KM2V8001CM chip read problem Can't read data with this chip, EDL not working (dont have loader), isp not working (error -113), socket not working. Anybody solution ? I try socket solution - remove 47 Ohm resistor and solder 22ohm, no change, still error. Phone - tested 2x A52 5G (A526B) |
Code: Z3X EasyJtag EMMC File Manager v 1.22 |
same problem Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: HIGH Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: ON UFS Safe Mode: ON Initialize UFS Engine Fail. Code: -113/ERROR_UFS_UPIU_NOP_RESULT_FAIL Scanner Thread Terminated Elapsed: 00:00:08:437 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. |
i am waiting for team response. |
ufs bga 254 micron Running EasyJtag UFS Mode... UFS ISP Mode: OFF UFS Safe Mode: ON Initialize UFS Engine Fail. Code: -112/ERROR_UFS_UPIU_BOOT_FAIL Scanner Thread Terminated Elapsed: 00:00:06:236 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: HIGH Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: OFF UFS Safe Mode: ON Initialize UFS Engine Fail. Code: -112/ERROR_UFS_UPIU_BOOT_FAIL Scanner Thread Terminated Elapsed: 00:00:12:589 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. |
https://forum.gsmhosting.com/vbb/f67...ected-3127385/ |
