Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #2 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Oct 2002 Location: Russia Age: 44
Member: 16794 Status: Offline Thanks Meter: 0 | hello. sorry all, but on russian ![]() у меня была такая же проблема. софт virtual прекрасно работает с версией прошивки 6.3.2 - лично проверял. после восстановления ИМЕ все прекрасно работает. так что ищи проблемы в кабеле... если что пиши . |
![]() | #4 (permalink) |
Major Poster ![]() ![]() Join Date: Feb 2003 Location: BG Age: 54
Member: 21955 Status: Offline Thanks Meter: 0 | http://www.r00t.host.sk/ with CTE Terminal |
![]() | #6 (permalink) |
Member: 16794 Status: Offline Thanks Meter: 0 | hello. try to use soft from virtualM v.2.00. take it here http://www.gsmfactory.us/software/re...ID=13&TypeID=1 enter good IMEI and press "unlock". for me work fine. good luck ![]() |
![]() | #9 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2001 Location: Hungary
Member: 7214 Status: Offline Thanks Meter: 0 | Hi, You have to use CTE Terminal sofware. If you have the prog try this method: Start CTE Terminal, choose COM port....connect to the phone, if connected: 1. pw (wap code) 2. power off phone and on 3. SLDefault - Clear all SIMLOCKs 4. FactoryReset 5. writeimei (real phone imei) 6. SLDefault 7. FactoryReset And phone work fine. P.S. For pw and writeimei pw 12345678 writeimei 0x12 0x34 0x56 0x78 0x90 0x12 0x34 0x5 WARNING!!! You can write the WAP CODE to the program only 1 time!!!!! After it the program won't accept!!! This is TESTED by me in a Sony J6 (imei was 00000000000), and J70. WORK 100% BR. Skydiver |
![]() | #13 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2002 Location: I
Member: 15238 Status: Offline Thanks Meter: 127 | ![]() i was also tired with direct data cables. Tried many configurations and schematics for Z5. But at last - one good solution i found for my two sony z5 phones. one was asking security code - other was sim lock USE UNIVERSAL BOX & CABLE {cable provided with it}. It is by default supplied with 9V. Virtual M works perfect with this cable. For clearing locks you guys can even use GL1 OR GL3 loader. Virtual M requires a perfect timing skill on starting it up AND on completion of whole process. GL3 also works fine. I got another Z5 today. simlocked. But i m not able to remove it. I got this result on LCD upon applying *#RELEASE# code. I m posting the result here. If anyone has got a clue, pl let us know. ![]() =========== SIM lock status ----------------- network Lock MCC=001 MNC=01GSM TA Net 00101Fail. count: 0 ----------------- SAT activated =========== ![]() Let's share our results. Let our knowledge Horizons expand. |
![]() | #14 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2013 Location: MOROCCO Age: 33
Member: 1945420 Status: Offline Thanks Meter: 29 | IF YOU HAVE IMEI NULL SONY Z5 E6653 FLASH WITH THIS FILE BY SETOOL BOX https://www.mediafire.com/file/0mfm9...EPARE.zip/file PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... \\.\EPIUSB2 \\?\USB#VID_0FCE&PID_ADDE#5&19288afc&0 &1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} RUNNING S1_BOOT VER "S1_Boot_MSM8994_LA1.2.2_38" ACTIVE_COMP_AID : 0004 HWCONF_AID : 0004 LOADER_AID : 0004 BOOT_AID : 0004 [ llcomm: 00400000,00080000 ] DEVICE ID: 017CB541 FLASH ID: "0011/01000000" LOADER VERSION: MSM8994_50 PHONE IMEI : 35964406264220 writing "C:\Users\lamrisli\Desktop\Z5\FSP_S1-MODEMSW-LIVE-F936-PID1-0006-MMC.zip" Processing package FSP_S1-MODEMSW-LIVE-F936-PID1-0006-MMC.zip Testing package integrity ... PROCESSING: amss_fs_1_S1-MODEMSW-LIVE-F936-PID1-0006-MMC.sin PROCESSING: amss_fsg_S1-MODEMSW-LIVE-F936-PID1-0006-MMC.sin PROCESSING: amss_fs_2_S1-MODEMSW-LIVE-F936-PID1-0006-MMC.sin Processing script "C:\Users\lamrisli\Desktop\tawrite000208B350000000 .txt" ... Writing TA unit 0002/08B3/0004 Elapsed: 4 seconds |
![]() | #15 (permalink) |
HELP!!! Who know how i can write IMEI to Z5? | vnc | Sony | 2 | 01-01-2004 18:23 |
Help my MT50 ver.07 lg.01 imei repair | SergeyM | x1x to x45/x50 | 3 | 07-29-2002 01:17 |
please help me repair azalis 288 imei | crossings | Philips | 0 | 06-07-2002 23:53 |
Big PROBLEM!!!...pls. HELP!... IMEI (656565) LOCKS(4 CLOSED) CAN IT BE REPAIRED? | Chryse | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 12 | 02-08-2002 07:16 |
Problem Changing imei on Z5 | Flash83 | Sony | 0 | 02-03-2002 14:38 |
