05-02-2024, 22:51 | #1 (permalink) |
Crazy Poster Join Date: Nov 2013 Location: colombia cordoba monteria
Member: 2066724 Status: Offline Thanks Meter: 6 | SM-A217M Unlock MDM Question [Answered] I have problems with this a21s that accepts the program but it relocks, it is not stable, it does not allow the equipment to be manipulated, I request re-entry of the credits Work ID: 0000000001E3E151 Starting Unlock MDM (Mar.2024) Selected model: SM-A217M Make factory data reset and connect the phone on first page of activation stage to PC via USB. Phone must be in Setup Wizard mode Connect powered-on device to PC! Searching modem port... OK Input IMEI: 356389810169877 Input SN: RF8R70KRM3A Connecting to server... Username: widaloba2 Your balance: 0 credits Sending device information.. OK Choose unlock method! QR code method choosen! Please check device using this QR before unlocking! Follow these steps : 1. In Android Setup Wizard mode tap on the blank space 6 times. 2. Scan this QR code to install MDM Guard service on your device. 3. Connect to Wi-Fi. 4. Follow the instructions on the screen. 5. Allow USB debugging mode when prompt appears on the screen. Searching ADB devices... Press "OK" button on the device to allow USB debugging OK QR Code is scanned Reading info... Detected model: SM-A217M Fingerprint: samsung/a21sub/a21s:12/SP1A.210812.016/A217MUBSBDWK1:user/release-keys Firmware compiled date: Wed Nov 8 23:19:24 KST 2023 PDA version: A217MUBSBDWK1 CSC version: A217MOWOBDWK1 SW version: A217MUBSBDWK1 Build number: QB25367532 Phone SN: RF8R70KRM3A Android version: 12 (SP1A.210812.016) Sales code: COO Carrier Id: COO Country: Colombia HW platform: exynos850 HW Chip: universal3830 HW Modem: MP 0.500 Security patch level: 2023-11-01 Warranty Void: 0 Codename: a21sub SIM 1 status: ABSENT SIM 2 status: ABSENT Modem board: SHANNON318 Starting exploit... Activating service... Method #1 currently not supported for this device. Do you want to use method #2? Using method #2 High security detected! When unlocking the device, the screen may blink for a few seconds. You can switch MdmGuard to alternative mode without lockscreen to remove this (read software help). Warning: After rebooting the device, a MDM lock may appear. MDM Guard service will turn off the screen and the MDM lock will disappear. This may happen a few times after reboot. MDM Guard service was activated. Complete the Setup Wizard on the device. MDM Guard service will restrict OTA updates on your device to prevent relock. Unlock MDM (Mar.2024) done Execution time 6 minute(s) 41 second(s) Performed by 4.3.0.1 Software version. |
05-03-2024, 06:33 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,157 | Hello. For some devices, you may need to perform the operation 2 to 5 times. Just try the operation again. That's why if your username and device serial number match, you can try the operation for free and an infinite number of times. Repeat operation and post here results. We'll check where can be the problem in more detail. |
The Following User Says Thank You to Octopus support For This Useful Post: |
05-03-2024, 16:17 | #3 (permalink) |
Member: 2066724 Status: Offline Thanks Meter: 6 | I tried many times then proceeded to throw it away the application came in but it is unstable there is constant relocking I left it for several days to see if it improved but nothing for that reason I ask for a refund of the credits since the program does not allow the cell phone to be manipulated due to its relocking |
