03-23-2023, 15:19 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Lagos Nigeria
Member: 61176 Status: Offline Sonork: 100.86572 Thanks Meter: 368 | a326u daed after read code attempt [Answered] no boot samsung. here is log 2023-03-23 14:01:07.120 [I] Welcome to Octoplus Samsung Software v.4.1.0 2023-03-23 14:01:19.941 [I] 2023-03-23 14:01:19.945 [W] Turn on USB debugging on the phone. Connect powered-on phone to PC using USB via ADB. 2023-03-23 14:01:19.945 [I] Searching ADB devices... 2023-03-23 14:01:20.959 [I] Press "OK" button on the device to allow USB debugging 2023-03-23 14:01:22.021 [I] OK 2023-03-23 14:01:22.022 [I] Reading info... 2023-03-23 14:01:22.149 [I] Detected model: SM-A326U 2023-03-23 14:01:22.149 [I] Fingerprint: samsung/a32xsq/a32x:12/SP1A.210812.016/A326USQS8BVL3:user/release-keys 2023-03-23 14:01:22.149 [I] Firmware compiled date: Fri Dec 9 14:16:05 KST 2022 2023-03-23 14:01:22.149 [I] PDA version: A326USQS8BVL3 2023-03-23 14:01:22.149 [I] CSC version: A326UOYN8BVL3 2023-03-23 14:01:22.149 [I] SW version: A326USQS8BVL3 2023-03-23 14:01:22.149 [I] Build number: A32X_USA_SINGLE 2023-03-23 14:01:22.149 [I] Phone SN: RFCR70BT00V 2023-03-23 14:01:22.149 [I] Android version: 12 (SP1A.210812.016) 2023-03-23 14:01:22.149 [I] Sales code: SPR 2023-03-23 14:01:22.149 [I] Carrier Id: XAA 2023-03-23 14:01:22.149 [I] Country: USA 2023-03-23 14:01:22.149 [I] HW platform: mt6853 2023-03-23 14:01:22.149 [I] HW Chip: mt6853 2023-03-23 14:01:22.149 [I] HW Modem: REV1.0 2023-03-23 14:01:22.149 [I] Security patch level: 2022-11-01 2023-03-23 14:01:22.149 [I] Warranty Void: 0 2023-03-23 14:01:22.149 [I] Codename: a32xsq 2023-03-23 14:01:22.149 [I] SIM 1 status: ABSENT 2023-03-23 14:01:22.149 [I] SIM 2 status: ABSENT 2023-03-23 14:01:22.149 [I] Modem board: MT6853 2023-03-23 14:01:26.245 [I] 2023-03-23 14:01:29.272 [I] Work ID: 000000000192111E 2023-03-23 14:01:29.291 [I] Starting Read Codes (Nov.2022) 2023-03-23 14:01:29.307 [I] Selected model: SM-A326U 2023-03-23 14:01:29.357 [W] Please connect device via Adb or Brom mode. If for some reason Soft Bricking doesn`t work, you will have to connect your device via Brom mode by Test Point. 2023-03-23 14:01:29.357 [I] Devices with Unlock App (branded to T-Mobile, MetroPCS, etc.) are not supported! Make sure device requests to enter unlock code and only then perform "Read Codes" operation! Do you want to continue? 2023-03-23 14:01:36.368 [I] Searching for devices... 2023-03-23 14:01:37.396 [I] Searching ADB devices... 2023-03-23 14:01:38.404 [I] Press "OK" button on the device to allow USB debugging 2023-03-23 14:01:39.456 [I] OK 2023-03-23 14:01:39.456 [I] Reading info... 2023-03-23 14:01:39.587 [I] Detected model: SM-A326U 2023-03-23 14:01:39.587 [I] Fingerprint: samsung/a32xsq/a32x:12/SP1A.210812.016/A326USQS8BVL3:user/release-keys 2023-03-23 14:01:39.587 [I] Firmware compiled date: Fri Dec 9 14:16:05 KST 2022 2023-03-23 14:01:39.587 [I] PDA version: A326USQS8BVL3 2023-03-23 14:01:39.587 [I] CSC version: A326UOYN8BVL3 2023-03-23 14:01:39.587 [I] SW version: A326USQS8BVL3 2023-03-23 14:01:39.587 [I] Build number: A32X_USA_SINGLE 2023-03-23 14:01:39.587 [I] Phone SN: RFCR70BT00V 2023-03-23 14:01:39.587 [I] Android version: 12 (SP1A.210812.016) 2023-03-23 14:01:39.587 [I] Sales code: SPR 2023-03-23 14:01:39.587 [I] Carrier Id: XAA 2023-03-23 14:01:39.587 [I] Country: USA 2023-03-23 14:01:39.587 [I] HW platform: mt6853 2023-03-23 14:01:39.587 [I] HW Chip: mt6853 2023-03-23 14:01:39.587 [I] HW Modem: REV1.0 2023-03-23 14:01:39.587 [I] Security patch level: 2022-11-01 2023-03-23 14:01:39.588 [I] Warranty Void: 0 2023-03-23 14:01:39.588 [I] Codename: a32xsq 2023-03-23 14:01:39.588 [I] SIM 1 status: ABSENT 2023-03-23 14:01:39.588 [I] SIM 2 status: ABSENT 2023-03-23 14:01:39.588 [I] Modem board: MT6853 2023-03-23 14:01:39.588 [I] Reading IMEI... 2023-03-23 14:01:39.588 [I] Searching modem port... 2023-03-23 14:01:50.335 [I] OK 2023-03-23 14:01:53.952 [I] Rebooting device... 2023-03-23 14:02:06.450 [I] OK 2023-03-23 14:02:06.452 [I] Writing pit file... 2023-03-23 14:02:06.452 [I] Connecting device in Download Mode... 2023-03-23 14:02:20.053 [I] OK 2023-03-23 14:02:20.053 [I] Connected successfully to port: COM291 2023-03-23 14:02:20.747 [I] Saved pit file backup to: C:/Program Files (x86)/Octoplus/Octoplus_Samsung/backups/SM-A326U_350091123351426_pit.bin 2023-03-23 14:02:20.747 [I] The pit file written successfully 2023-03-23 14:02:21.748 [I] Reconnecting... 2023-03-23 14:02:21.748 [I] Writing bootloader... 2023-03-23 14:02:21.748 [I] Connecting device in Download Mode... 2023-03-23 14:02:35.764 [I] OK 2023-03-23 14:02:35.764 [I] Connected successfully to port: COM291 2023-03-23 14:02:35.867 [I] The bootloader written successfully 2023-03-23 14:02:43.027 [W] MTK port not found. Reconnect USB cable to the device and check if there is MTK port in device manager. Install driver if need and press "Ok" button to continue. 2023-03-23 14:03:19.146 [W] Try to install MTK USB driver from 'Help' section and repeat operation again. With any questions contact support. 2023-03-23 14:03:19.147 [I] Restoring bootloader... 2023-03-23 14:03:19.147 [I] Device is not connected 2023-03-23 14:03:19.147 [W] Currently, "Read codes" operation is not supported for your phone's firmware version,please contact support team. 2023-03-23 14:03:19.200 [I] Read Codes (Nov.2022) failed 2023-03-23 14:03:19.214 [I] Execution time 1 minute(s) 49 second(s) 2023-03-23 14:03:19.226 [I] Performed by 4.1.0 Software version. |
03-27-2023, 17:41 | #3 (permalink) | |
Member: 61176 Status: Offline Sonork: 100.86572 Thanks Meter: 368 | Quote:
2023-03-23 14:11:30.076 [I] 2023-03-23 14:11:34.092 [I] Work ID: 0000000001E29BBE 2023-03-23 14:11:34.099 [I] Starting Restore device 2023-03-23 14:11:34.109 [I] Selected model: SM-A326U 2023-03-23 14:11:34.109 [W] - Use this future if you need to restore your device after unsuccessful operation. 2023-03-23 14:11:34.109 [I] Searching MTK device... 2023-03-23 14:11:34.146 [I] Detected MediaTek USB Port 2023-03-23 14:11:41.548 [I] Restore device failed 2023-03-23 14:11:41.557 [I] Execution time 7 second(s) 2023-03-23 14:11:41.568 [I] Performed by 4.1.0 Software version. 2023-03-23 14:11:48.451 [I] 2023-03-23 14:11:52.308 [I] Work ID: 0000000001E29BCB 2023-03-23 14:11:52.319 [I] Starting Restore device 2023-03-23 14:11:52.332 [I] Selected model: SM-A326U 2023-03-23 14:11:52.332 [W] - Use this future if you need to restore your device after unsuccessful operation. 2023-03-23 14:11:52.332 [I] Searching MTK device... 2023-03-23 14:11:52.358 [I] Detected MediaTek USB Port 2023-03-23 14:11:54.765 [I] Restore device failed 2023-03-23 14:11:54.777 [I] Execution time 2 second(s) 2023-03-23 14:11:54.790 [I] Performed by 4.1.0 Software version. 2023-03-23 14:12:04.067 [I] 2023-03-23 14:12:06.827 [I] Work ID: 0000000001921276 2023-03-23 14:12:06.838 [I] Starting Read Codes (Nov.2022) 2023-03-23 14:12:06.850 [I] Selected model: SM-A326U 2023-03-23 14:12:06.900 [W] Please connect device via Adb or Brom mode. If for some reason Soft Bricking doesn`t work, you will have to connect your device via Brom mode by Test Point. 2023-03-23 14:12:06.900 [I] Devices with Unlock App (branded to T-Mobile, MetroPCS, etc.) are not supported! Make sure device requests to enter unlock code and only then perform "Read Codes" operation! Do you want to continue? 2023-03-23 14:12:09.094 [I] Searching for devices... 2023-03-23 14:12:09.113 [I] Searching MTK device... 2023-03-23 14:12:09.127 [I] Detected MediaTek USB Port 2023-03-23 14:12:11.524 [I] Read Codes (Nov.2022) failed 2023-03-23 14:12:11.543 [I] Execution time 4 second(s) 2023-03-23 14:12:11.550 [I] Performed by 4.1.0 Software version. 2023-03-23 14:12:28.963 [I] 2023-03-23 14:12:31.792 [I] Work ID: 0000000001921288 2023-03-23 14:12:31.803 [I] Starting Restore device 2023-03-23 14:12:31.816 [I] Selected model: SM-A326U 2023-03-23 14:12:31.816 [W] - Use this future if you need to restore your device after unsuccessful operation. 2023-03-23 14:12:31.816 [I] Searching MTK device... 2023-03-23 14:12:31.833 [I] Detected MediaTek USB Port 2023-03-23 14:12:34.234 [I] Restore device failed 2023-03-23 14:12:34.254 [I] Execution time 2 second(s) 2023-03-23 14:12:34.266 [I] Performed by 4.1.0 Software version. 2023-03-23 14:13:21.426 [I] 2023-03-23 14:13:23.782 [I] Work ID: 00000000019212A3 2023-03-23 14:13:23.804 [I] Starting Restore device 2023-03-23 14:13:23.820 [I] Selected model: SM-A326U 2023-03-23 14:13:23.820 [W] - Use this future if you need to restore your device after unsuccessful operation. 2023-03-23 14:13:23.820 [I] Searching MTK device... 2023-03-23 14:13:23.835 [I] Detected MediaTek USB Port 2023-03-23 14:13:26.236 [I] Restore device failed 2023-03-23 14:13:26.251 [I] Execution time 2 second(s) 2023-03-23 14:13:26.264 [I] Performed by 4.1.0 Software version. 2023-03-23 14:13:35.059 [I] 2023-03-23 14:13:37.730 [I] Work ID: 00000000019212AD 2023-03-23 14:13:37.755 [I] Starting Restore device 2023-03-23 14:13:37.771 [I] Selected model: SM-A326U 2023-03-23 14:13:37.771 [W] - Use this future if you need to restore your device after unsuccessful operation. 2023-03-23 14:13:37.771 [I] Searching MTK device... 2023-03-23 14:13:37.791 [I] Detected MediaTek USB Port 2023-03-23 14:13:40.190 [I] Restore device failed 2023-03-23 14:13:40.214 [I] Execution time 2 second(s) 2023-03-23 14:13:40.229 [I] Performed by 4.1.0 Software version. 2023-03-23 14:13:47.954 [I] 2023-03-23 14:13:50.263 [I] Work ID: 00000000019212B8 2023-03-23 14:13:50.288 [I] Starting Restore device 2023-03-23 14:13:50.309 [I] Selected model: SM-A326U 2023-03-23 14:13:50.309 [W] - Use this future if you need to restore your device after unsuccessful operation. 2023-03-23 14:13:50.309 [I] Searching MTK device... 2023-03-23 14:13:50.327 [I] Detected MediaTek USB Port 2023-03-23 14:13:52.731 [I] Restore device failed 2023-03-23 14:13:52.756 [I] Execution time 2 second(s) 2023-03-23 14:13:52.772 [I] Performed by 4.1.0 Software version. 2023-03-23 14:16:54.250 [I] 2023-03-23 14:16:58.068 [I] Work ID: 0000000001E29C59 2023-03-23 14:16:58.094 [I] Starting Restore device 2023-03-23 14:16:58.111 [I] Selected model: SM-A326U 2023-03-23 14:16:58.111 [W] - Use this future if you need to restore your device after unsuccessful operation. 2023-03-23 14:16:58.111 [I] Searching MTK device... 2023-03-23 14:16:58.129 [I] Detected MediaTek USB Port 2023-03-23 14:17:00.539 [I] Restore device failed 2023-03-23 14:17:00.564 [I] Execution time 2 second(s) 2023-03-23 14:17:00.578 [I] Performed by 4.1.0 Software version. | |
