A500fu emergency call after writing cert Platform: Samsung Android Selected port: COM18 Selected model: SM-A500FU Selected file: E:\SAMSUNG FILE\Cert ok\cert-sm-a500fu_359536019154806_rf8g105m6pd.cert Detected phone model: SM-A500FU Firmware compiled date: Wed Apr 1 18:34:14 KST 2015 PDA version: A500FUXXU1AOD1 CSC version: A500FUVFR1AOD1 SW version: A500FUXXU1AOD1 Phone IMEI: ************ Phone SN: RF8G11D3Z1P Android version: 4.4.4 (KTU84P) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes. Writing cert ok but emergency call only. I cant write qcn too. When going to write always failed Platform: Samsung Android Selected port: COM19 Selected model: SM-A500FU Reading info... Phone was not found on the selected port! Writing QCN failed Please help me too solved this problem. |
Hello. Please use the latest Software version. Make backup of phone's QCN via "Read QCN" operation, then try to write a QCN file again. Try to perform the operation on different COM ports, with enabled "Manual select" option. |
hello could you please send me a500fu cert file. |
All Cert files, which we have at the moment, are available in "Samsung/For unlock and repair/Certificates" folder of the Support Area (Cert files compatibility). To enter Support Area, press "Go to support" button on "Support & options" tab of the Software. Also You can use Files Downloader on "Support & options" tab of the Software to browse, search and download files from the Support Area. |
