05-26-2017, 13:50 | #3 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2134457 Status: Offline Thanks Meter: 13 | Welcome to Octoplus/Octopus Box Samsung software version 2.5.4 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-A510F Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Boot section... Boot section has been written successfully. Searching for a phone (waiting for ADB device)... Reading info... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Proper android device not found. Make shure that "USB debug" option |
05-26-2017, 14:22 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | "boot.img" that is being used to enable ADB, can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares). To remove FRP lock You can try to write older by release date firmware, then repeat "Reset FRP" operation. |
