Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 04-10-2014, 12:32   #1 (permalink)
Member: 1418524
Thanks Meter: 186
GT-C3303I Sending preloader failed [Solved]
Welcome to Octoplus/Octopus Box Samsung software version 1.5.2
To connect SM-N900 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Builds numbers" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
Selected firmware file: C3303iJPKB1_OJPKB4.oct
Platform: Samsung Swift
Selected model: GT-C3303I
Selected port: USB
Please, press "volume up" and "lock" connect phone to USB without
battery.
Connecting...
Phone found.
Chipset version : 0A
SCROM version : 33
Sending loaders...
Sending preloader failed.
Old 04-10-2014, 12:36   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,413
We have sent You test Software version to your PM. Try with this version and write the result.
Old 04-10-2014, 13:22   #3 (permalink)
Member: 1418524
Thanks Meter: 186
Welcome to Octoplus/Octopus Box Samsung software version 1.5.2.1
Selected firmware file: C3303iDXKB1_OLAKB1.oct
Selected port: USB
battery.
Connecting...
Phone found.
SCROM version : 33
Sending loaders...
Selected port: USB
battery.
Connecting...
Phone found.
SCROM version : 33
Sending loaders...
Preloader send successfully
Conecting to pipes...
Successfully conecte to pipes.
Writing firmware...
Writing Firmware
Writing partition LCDACT ...
Erasing block...
Block erase successfully.
Writing block...
Partition LCDACT write successfully.
Writing partition MAIN ...
Erasing block...
Writing block...
Partition MAIN write successfully.
Writing partition DSP ...
Erasing block...
Writing block...
Partition DSP write successfully.
Writing partition ROOT ...
Erasing block...
Writing block...
Partition ROOT write successfully.
Writing partition TFS ...
Partition TFS write successfully.
Writing partition CSC ...
Partition CSC write successfully.
Firmware Write successfully.
Selected port: COM1
Baud rate: 921600
Please, connect phone to UART cable, insert battery and press power
button for 3 seconds.
Connecting...
Connecting canceled.
Selected port: COM3
Baud rate: 921600
Connecting...
Phone in TAT mode.
Reading info, please wait...
Phone IMEI A: 357-------------
SW version: C3303iDXK
Bluetooth MAC: CCF9E8591EA8
Phone SN : RV1B913236
Reading codes...
Deactivating MSL...
MSL deactivate successfully
Freeze lock: 62776000
Net lock: 00000000
Sim lock: 00000000
Phone lock: 00000000
Sp lock: 00000000
All Done thank to fast Support
Page generated in 0.13282 seconds with 8 queries
