07-29-2020, 05:44 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: World
Member: 792851 Status: Offline Thanks Meter: 136 | E330l network lock but can not connect to octopus [Answered] Code: Welcome to Octoplus Box Samsung software version 2.9.6.2 Card S/N : 0101786F ----------------------------------------------------------------------------------- To connect SM-G570Y phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SHV-E330L phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+MODEM+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090# or *#0808#" number. 12. Set "Diag config" to "DM/DUM over HSIC" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SHV-E330L Operation: Unlock Reading info... Phone was not found on the selected port! Phone unlocking failed Performed by 2.9.6.2 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SHV-E330L Operation: Unlock Reading info... Phone was not found on the selected port! Phone unlocking failed Performed by 2.9.6.2 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SHV-E330L Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM22 Phone connection failed No diagnostic ports found! Connecting to phone on COM4 Phone connection failed Performed by 2.9.6.2 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SHV-E330L Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM22 Phone connection failed No diagnostic ports found! Connecting to phone on COM4 Phone connection failed Performed by 2.9.6.2 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SHV-E330L Operation: Unlock Reading info... Phone was not found on the selected port! Phone unlocking failed Performed by 2.9.6.2 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SHV-E330L Operation: Unlock Reading info... Phone was not found on the selected port! Phone unlocking failed Performed by 2.9.6.2 Software version. Also when I choose dm-modem-adb ADB port gone from device manager When I choose adb-mtp then I can see adb device on device manager Last edited by salim5566; 07-29-2020 at 06:37. |
07-29-2020, 07:42 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. Please, try to reflash your device with another firmware (another region) after repeat operation again, according to Software manual |
07-30-2020, 04:36 | #3 (permalink) | |
Member: 792851 Status: Offline Thanks Meter: 136 | Quote:
Hi after flash now I can connect phone I have unlock network lock but when I put simcard I get this message and I don’t see any network Code: Welcome to Octoplus Box Samsung software version 2.9.6.2 Card S/N : 0101786F ----------------------------------------------------------------------------------- To connect SHV-E330L phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+MODEM+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090# or *#0808#" number. 12. Set "Diag config" to "DM/DUM over HSIC" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM4 Selected model: SHV-E330L Mode: Emergency Unlock for SHV-E330L phone in emergency mode can’t be done Performed by 2.9.6.2 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM60 Selected model: SHV-E330L Mode: Normal Phone model: AAAAANAZ Warning: Selected model (SHV-E330L) differs from the detected one (AAAAANAZ)! Firmware compiled date: Jan 06 2014 Firmware compiled time: 19:00:00 Firmware released date: Jul 17 2014 Firmware released time: 12:25:38 Phone IMEI: 356427-05-491062-0 SW version: Performed by 2.9.6.2 Software version. ----------------------------------------------------------------------------------- To connect SM-G570Y phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SHV-E330L phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+MODEM+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090# or *#0808#" number. 12. Set "Diag config" to "DM/DUM over HSIC" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM60 Selected model: SHV-E330L Operation: Unlock Reading info... Mode: Normal Firmware compiled date: Jan 06 2014 Firmware compiled time: 19:00:00 Firmware released date: Jul 17 2014 Firmware released time: 12:25:38 SW Version: M8974A-AAAANAZM-1.0.180104 Please, press "OK" button on the phone to allow USB debugging. Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SHV-E330L Firmware compiled date: Mon Oct 6 08:38:42 KST 2014 PDA version: E330LKLUCNJ1 CSC version: E330LLGTCNJ1 SW version: E330LKLUCNG5 Build number: Phone IMEI: 356427054910620 Phone SN: R39F7000LN Android version: 4.4.2 (KOT49H) Sales code: LGT Country: KOREA HW platform: msm8974 HW Chip: MSM8974 HW Modem: MSM8974 Warranty Void: 0 SIM 1 status: ready Codename: ks01ltelgt Checking Root: Phone is not Rooted. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked Performed by 2.9.6.2 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM60 Selected model: SHV-E330L Mode: Normal Phone model: SHV-E330L Firmware compiled date: Jan 06 2014 Firmware compiled time: 19:00:00 Firmware released date: Jul 17 2014 Firmware released time: 12:25:38 Phone IMEI: 356427-05-491062-0 SW version: M8974A-AAAANAZM-1.0.180104 Creating NVM backup Reading NVM done! Repairing NVM for SHV-E330L phone... NVM repair completed successfully To finish the operation, please restart the phone via phone's menu. Performed by 2.9.6.2 Software version. | |
07-30-2020, 07:45 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Quote:
Take out SIM card from phone. Connect powered-on phone to PC via Micro USB cable. Install necessary driver. Click "Unlock" button. Follow software instructions (prompts). | |
07-31-2020, 00:34 | #5 (permalink) | |
do i need to root this phone? it show unlock on software but it dont get unlock Code: Platform: Samsung Android Selected port: COM60 Selected model: SHV-E330L Operation: Unlock Reading info... Mode: Normal Firmware compiled date: Jan 06 2014 Firmware compiled time: 19:00:00 Firmware released date: Jul 17 2014 Firmware released time: 12:25:38 SW Version: M8974A-AAAANAZM-1.0.180104 Detected phone model: SHV-E330L Firmware compiled date: Mon Oct 6 08:38:42 KST 2014 PDA version: E330LKLUCNJ1 CSC version: E330LLGTCNJ1 SW version: E330LKLUCNG5 Build number: Phone IMEI: 356427054910620 Phone SN: R39F7000LN Android version: 4.4.2 (KOT49H) Sales code: LGT Country: KOREA HW platform: msm8974 HW Chip: MSM8974 HW Modem: MSM8974 Warranty Void: 0 SIM 1 status: absent Codename: ks01ltelgt Checking Root: Phone is not Rooted. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked Performed by 2.9.6.2 Software version. | |
07-31-2020, 00:46 | #6 (permalink) | |
Code: Platform: Samsung Android Selected port: COM60 Selected model: SHV-E330L Operation: Unlock Reading info... Mode: Normal Firmware compiled date: Jan 06 2014 Firmware compiled time: 19:00:00 Firmware released date: Jul 17 2014 Firmware released time: 12:25:38 SW Version: M8974A-AAAANAZM-1.0.180104 Detected phone model: SHV-E330L Firmware compiled date: Mon Oct 6 08:38:42 KST 2014 PDA version: E330LKLUCNJ1 CSC version: E330LLGTCNJ1 SW version: E330LKLUCNG5 Build number: Phone IMEI: 356427054910620 Phone SN: R39F7000LN Android version: 4.4.2 (KOT49H) Sales code: LGT Country: KOREA HW platform: msm8974 HW Chip: MSM8974 HW Modem: MSM8974 Warranty Void: 1 SIM 1 status: absent Codename: ks01ltelgt Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SHV-E330L-31-07-2020_11-43-22 file Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked Performed by 2.9.6.2 Software version. | |
