06-06-2016, 23:25 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | FRP remove n920p 6.0.1 fails [Solved] Code: INFO : 06/06/2016 17:54:57 > Platform: Samsung Android INFO : 06/06/2016 17:54:57 > Selected port: COM1 INFO : 06/06/2016 17:54:57 > Selected model: SM-G920P WARN : 06/06/2016 17:54:57 > To put SM-G920P into Download Mode, You have to perform the following steps: WARN : 06/06/2016 17:54:57 > 1. Reconnect the battery. WARN : 06/06/2016 17:54:57 > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 06/06/2016 17:54:57 > 3. When phone turns on, press "Volume+" key. INFO : 06/06/2016 17:54:57 > Searching for a phone. Please wait... INFO : 06/06/2016 17:55:46 > Phone found. INFO : 06/06/2016 17:55:46 > Initializing.. INFO : 06/06/2016 17:55:46 > Resetting FRP lock.. SUCC : 06/06/2016 17:55:46 > success INFO : 06/06/2016 17:55:46 > Resetting EE lock.. SUCC : 06/06/2016 17:55:46 > success INFO : 06/06/2016 17:55:46 > Resetting Samsung Account lock.. SUCC : 06/06/2016 17:55:46 > success ERROR : 06/06/2016 17:55:56 > Operation was failed! INFO : 06/06/2016 17:55:56 > Performed by 2.2.6 software version Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\06-06-2016_17-53-55.log" closed (06/06/2016 18:07:14). Last edited by Octopus box; 06-11-2016 at 11:38. |
The Following User Says Thank You to yurais For This Useful Post: |
06-07-2016, 10:57 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. You can try write SBoot of older (by release date) firmware via "Write Firmware" operation, with enabled "Advanced Mode" option, then repeat "Reset FRP/Reactivatin/EE" operation. |
06-07-2016, 16:42 | #3 (permalink) | |
Member: 220595 Status: Offline Thanks Meter: 355 | Quote:
Any idea where to get sboot? Enviado desde mi SM-N920T mediante Tapatalk | |
06-07-2016, 16:58 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | You will be able to select only SBoot partition of a firmware during "Write Firmware" operation with enabled "Advanced Mode" option. |
06-07-2016, 18:24 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Currently we don't have a tested SBoot file for this model. If You can find a separate Sboot partition - of course You can use only it. |
06-08-2016, 02:39 | #8 (permalink) | |
Am not sure about this. Maybe phone will only regurgitation to flash the file and nothing happens. Enviado desde mi SM-N920T mediante Tapatalk | |
06-10-2016, 03:43 | #9 (permalink) | |
I dot think It will accept sboot from lollipop firmweares, but will try tomorrow is there a 6.0.1 release for n920p before PC3? PC3 is the first release which appears in sammobile. | |
07-01-2016, 23:10 | #14 (permalink) |
Freak Poster Join Date: Sep 2013 Location: Tepa,HnD
Member: 2033258 Status: Offline Thanks Meter: 61 | guys i had download 5.1.1 firmware in order to downgrade the phone from 6.0.1 and it did work like charm.. just make sure you do a hard reset and wipe cache partition and make sure you go back straight to download mode in order to load true odin. hope this will help.. i personally download 5.1.1 OK3 cheers |
