12-16-2014, 21:42 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Labradors world
Member: 889070 Status: Offline Sonork: 100.1602568 Thanks Meter: 12 | G313HN - how made rooted & unlocked ----------------------------------------------------------------------------------- To connect SM-G313HN phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-G313HN Detected phone model: SM-G313HN Firmware compiled date: Wed Jul 2 22:09:29 KST 2014 PDA version: G313HNXXU0ANG2 CSC version: G313HNDBT0ANG1 SW version: G313HNXXU0ANG2 Phone IMEI: 35614506033XXX2 Phone SN: R51FA0X34FP Android version: 4.4.2 (KOT49H) Checking Root: Phone is not Rooted. Phone unlocking failed Question> How made this phone rooted/unlocked? Last edited by cardlinux; 12-16-2014 at 21:49. |
The Following User Says Thank You to cardlinux For This Useful Post: |
12-16-2014, 21:49 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. You can try to root the phone by doing the next: 1. Write "G313HNDDU0ANH2_ROOT.oct" file from the Support Area. 2. Root the phone with iRoot Software. |
12-16-2014, 22:07 | #3 (permalink) |
Member: 889070 Status: Offline Sonork: 100.1602568 Thanks Meter: 12 | I got this message> Welcome to Octoplus/Octopus Box Samsung software version 1.7.8 ----------------------------------------------------------------------------------- To connect SM-G313HN phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: G313HUDDU0ANH2_ROOT.oct Please put the phone into Download Mode and connect USB cable. To put SM-G313HN into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on File has been created for a different phone model. |
12-17-2014, 08:17 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | We will check the firmware and re-upload it. |
12-17-2014, 13:46 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | We have re-uploaded file into the Support Area. |
12-18-2014, 07:21 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | "G313HNDDU0ANH2_ROOT.oct" is for SM-G313HN, "G313HUDDU0ANH2_ROOT.oct" - for SM-G313HU. |
12-18-2014, 12:09 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Have You redownloaded file? Please re-download and try again. Last edited by Octopus box; 12-18-2014 at 14:26. |
11-20-2015, 07:20 | #10 (permalink) | |
Freak Poster Join Date: Jul 2013 Location: Banjul, The Gambia
Member: 1974557 Status: Offline Sonork: 00011nd Thanks Meter: 39 | Quote:
hello sir, after writing the above mentioned file from the support area, phone hanged on the logo. what should i do? | |
The Following User Says Thank You to ndubuaku For This Useful Post: |
11-20-2015, 10:23 | #12 (permalink) |
Member: 1974557 Status: Offline Sonork: 00011nd Thanks Meter: 39 | @Xerraco, i have flashed stock firmware all is back normal. but i repeated the rooting and it stocked on the same Logo. any idea how to Root? |
11-20-2015, 10:33 | #13 (permalink) | |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Quote:
Flash custom recovery CWM_6.0.5.1_SM-G313HN.zip install UPDATE-SuperSU-v2.46.zip from cwm recovery problem solved | |
The Following User Says Thank You to malka4u For This Useful Post: |
11-21-2015, 12:56 | #14 (permalink) |
Member: 1974557 Status: Offline Sonork: 00011nd Thanks Meter: 39 | @Malka4u, i think i am having stock rom issue. i am unable to flash cwm_6.0.5.1_smG313GHN.zip. i flashed few firmwares i have in hand including those i got from support. But try to flash cwm_6.0.5.1_smG313GHN.zip from odin but always move an inch and stop. i also try from recovery by sdcard still got error. can you please assist me with a good stock rom. |
