g530f emergency call hello 1st tell how write cert on g530f? i try with direct cable ,without battry termanil block 2nd with urt cable 3rd urt cable with block termnal but with URT its not connecting how and why?? Platform: Samsung Android Selected port: COM3 Selected model: SM-G530F Selected file: C:\Users\DAVED\Downloads\Cert-SM-G530F_355965060136244_R123456789S.cert Select Certificate2... Selected file: C:\Users\DAVED\Downloads\Cert-SM-G530F_355965060136244_R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Phone was not found Writing Certificate failed Performed by 2.4.7 Software version. after i write cert with another box , but still emergency call ??? |
Hello. To connect the phone via UART, You need to block highlighted pin with a tape/paper and use Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor for connection. http://i.imgur.com/wfV60I2l.jpg Also, please manually select COM port of the box in Software. |
but as i say i write cert another box but still emergency call sometime it take signals but still emergency again ok i,ll again reset msl . EFS sec and write again |
Such issue can occur if IMEI of Cert file is black listed. Also You can try to write a QCN from another, correctly working SM-G530F (remember to make backup of phone's original QCN). |
imei is OK is our country , but in another country its blacklisted |
still same o connect GT-I9190 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM75 Selected model: SM-G530F Selected file: C:\Users\DAVED\Downloads\Cert-SM-G530F_355965060136244_R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Phone was not found Writing Certificate failed Performed by 2.4.7 Software version. |
Try to reinstall FTDI drivers (http://octoplusbox.com/files/drivers...rs_2.08.24.zip). Try to use another Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor for connection. |
Platform: Samsung Android Selected port: COM75 Selected model: SM-G530F Selected file: C:\Users\DAVED\Downloads\Cert-SM-G530F_355965060136244_R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... :( |
Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 ----------------------------------------------------------------------------------- To connect SM-G530F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM75 Selected model: SM-G530F Selected file: C:\Users\DAVED\Downloads\Cert-SM-G530F_355965060136244_R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Phone was not found Writing Certificate failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G530F Selected file: C:\Users\DAVED\Downloads\Cert-SM-G530F_355965060136244_R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Phone was not found Writing Certificate failed Performed by 2.4.7 Software version. |
If You've blocked necessary battery pin, re-installed FTDI drivers and tried to use another Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor for connection, but problem remains - try to use another box as UART interface. |
ok write cert with another, but its still after a few minuts emergency call, :( i write it another OK qcn , so after that it work for sometime but again still emergency call the cert is from your support , and the whole net searched but found just your cert file, not have another cert file in case now i manage another set so how can i read :( kindly do something |
Unfortunately reading of Cert files from Qualcomm-based phones is not possible at the moment. |
so now solution for that? :( |
Yes, unfortunately no solution for reading Cert files from Qualcomm-based phones at the moment. |
