g530h USB debug info problem Welcome to Octoplus/Octopus Box Samsung software version 1.9.2 ----------------------------------------------------------------------------------- To connect SM-G530H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM95 Selected model: SM-G530H Mode: Normal Phone model: SM-G530H Firmware compiled date: Sep 20 2014 Firmware compiled time: 08:00:00 Firmware released date: Sep 23 2014 Firmware released time: 09:55:53 Phone IMEI: 357213-06-098416-6 SW version: MPSS.DPM.1.0.c7.1-00034-M8916EAAAANVZM-1.5920.1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM95 Selected model: SM-G530H Mode: Normal Phone model: SM-G530H Firmware compiled date: Sep 20 2014 Firmware compiled time: 08:00:00 Firmware released date: Sep 23 2014 Firmware released time: 09:55:53 Phone IMEI: 357213-06-098416-6 SW version: MPSS.DPM.1.0.c7.1-00034-M8916EAAAANVZM-1.5920.1 Reading NVM... Reading NVM done! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM95 Selected model: SM-G530H Proper android device not found. Make shure that "USB debug" option on the device is turned on. Reading EFS failed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM95 Selected model: SM-G530H Proper android device not found. Make shure that "USB debug" option on the device is turned on. Reading security failed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM95 Selected model: SM-G530H Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. |
Most likely, You have not installed the latest drivers. Disconnect all other devices from PC, re-install drivers (http://octoplusbox.com/files/drivers...ile_Phones.exe), re-boot the PC, turn on USB Debugging Mode and try again. Also, try to make Factory data reset and wipe cache partition and repeat. |
