Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 04-26-2016, 19:26   #1 (permalink)
flechazo's Avatar
Member: 39250
Thanks Meter: 64
G531F Imei repaired And Still
Welcome to Octoplus/Octopus Box Samsung software version
2.2.5
Platform: Samsung Android
Selected port: COM1
Selected model: SM-G531F
Detected phone model: SM-G531F
Firmware compiled date: Tue Aug 4 19:58:27 KST 2015
PDA version: G531FXXU1AOH1
CSC version: unknown
SW version: G531FXXU1AOK3
Phone SN: 00000000000
Android version: 5.1.1 (LMY48B)
Country: unknown
HW platform: mrvl
HW Chip: PXA19xx
HW Modem: unknown
Codename: grandprimeveltexx
Cheking Root
Phone is Rooted
Preparing...
Writing Certificate...
Selected file: D:\BOX FAI\Octopus\Samsung\Certificate\cert-sm-
g531f_35230207313620.cert
Checking Certificate file...
Certificate file successfully checked
Finalizing...
Certificate has been written successfully
Please, restart the phone to apply changes
Performed by 2.2.5 software version
Selected port: COM1
Searching for a phone. Please wait...
Phone found.
Country: unknown
HW platform: mrvl
HW Chip: PXA19xx
HW Modem: unknown
after restart problem still same
Old 04-26-2016, 22:03   #2 (permalink)
FaizanChauhaan's Avatar
Member: 2564757
Sonork: 100.1673410
Thanks Meter: 27
1st reflash that fone thn Retry..
Old 04-27-2016, 10:43   #3 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 26,503
Hello.
Most likely problem with IMEI is caused by damaged modem:
HW Modem: unknown
Please make Factory Reset and reflash the phone. Check whether modem will be correct (not unknown) after writing of a firmware.
Old 04-27-2016, 11:40   #4 (permalink)
flechazo's Avatar
Member: 39250
Thanks Meter: 64
and now
2.2.5
To connect GT-S6102 phone you have to perform the following
steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When the message appears press "Yes".
5. Connect USB cable to the phone.
6. Press "Read Info" in software.
Selected firmware file: G531FXXU1AOF7_ROOT.oct
Please put the phone into Download Mode and connect USB cable.
To put SM-G531F into Download Mode, You have to perform the
following steps:
1. Reconnect the battery.
2. Press and hold "Volume-" +"Power"+''Home" keys.
Found phone on
Firmware write started.
Writing SYSTEM section...
SYSTEM section has been written successfully.
Firmware writing successfully completed.
Selected port: COM1
Please, press "OK" button on the phone to allow USB debugging..
Firmware compiled date: Sat Jun 13 21:07:21 KST 2015
PDA version: G531FXXU1AOF7
Country: unknown
HW platform: mrvl
HW Chip: PXA19xx
HW Modem: unknown
Cheking Root
Phone is Rooted
Preparing...
g531f_35230307313620.cert
Finalizing...
Old 04-27-2016, 12:08   #5 (permalink)
flechazo's Avatar
Member: 39250
Thanks Meter: 64
Other firmware
Selected firmware file: G531FXXU1AOF7_PHN1AOF2.oct
following steps:
Found phone on
Writing PIT section...
PIT section has been written successfully.
Writing SBOOT section...
SBOOT section has been written successfully.
Writing SBOOT2 section...
SBOOT2 section has been written successfully.
Writing LOKE2ND section...
LOKE2ND section has been written successfully.
Writing LOKE1ST section...
LOKE1ST section has been written successfully.
Writing PARAM section...
PARAM section has been written successfully.
Writing KERNEL section...
KERNEL section has been written successfully.
Writing RECOVERY section...
RECOVERY section has been written successfully.
Writing NVM section...
NVM section has been written successfully.
Writing MODEM section...
MODEM section has been written successfully.
Writing CACHE section...
CACHE section has been written successfully.
Writing HIDDEN section...
HIDDEN section has been written successfully.
Selected port: COM1
Phone found.
CSC version: G531FPHN1AOF2
SW version: G531FXXU1AOF7
Country: The Netherlands
HW platform: mrvl
HW Chip: PXA19xx
HW Modem: unknown
Old 04-27-2016, 12:19   #6 (permalink)
Member: 1146942
Sonork: 100.1587278
Try to re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). If problem will remain - most likely phone has HW problem.
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.12478 seconds with 7 queries
