11-07-2014, 04:59 | #1 (permalink) |
Insane Poster Join Date: May 2010
Member: 1294744 Status: Offline Thanks Meter: 2 | i9300 baseband unknown octoplus I need a efs file v2 for this phone with the *aefs extension so i can repair it with my octoplus box ????? |
11-07-2014, 07:42 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Quote:
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair EFS" and "Repair IMEI" operations. It is not possible to repair IMEI, if phone's modem part is damaged. | |
The Following 3 Users Say Thank You to Octopus box For This Useful Post: |
11-09-2014, 09:45 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You can try to write any firmwares, which You have. |
11-10-2014, 08:15 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
If after of writing all firmwares which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). Try to change eMMC. | |
