05-05-2016, 04:41 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | J7 J700f after write cert no service? [Solved] Code: Welcome to Octoplus/Octopus Box Samsung software version 2.1.9 ----------------------------------------------------------------------------------- To connect SM-G925I phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-J700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-J700F Selected file: C:\Users\salim\Desktop\cert\j700f\cert-sm-j700f_ 352843074615490_r28g8208kwd.cert Select Certificate2... Selected file: C:\Users\salim\Desktop\cert\j700f\cert-sm-j700f_ 352842074615492_r28g8208kwd.cert ADB server killed. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-J700F Selected file: C:\Users\salim\Desktop\cert\j700f\cert-sm-j700f_ 352843074615490_r28g8208kwd.cert Select Certificate2... Operation was canceled Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-J700F Selected file: C:\Users\salim\Desktop\cert\j700f\cert-sm-j700f- 353237072915813-r51gb1s9kbz.cert Select Certificate2... Selected file: C:\Users\salim\Desktop\cert\j700f\cert-sm-j700f- 353236072915815-r51gb1s9kbz.cert ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-J700F Firmware compiled date: Fri Apr 15 21:36:16 KST 2016 PDA version: J700FXXU2APD8 CSC version: J700FODD2APD4 SW version: J700FXXU2APD3 Phone SN: RZ8GC0JDWJT Android version: 5.1.1 (LMY48B) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-J700F-Unknown30-04-2016_15-29-39-.asec file Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes Last edited by Octopus box; 05-07-2016 at 11:33. |
The Following User Says Thank You to MUTUAL For This Useful Post: |
05-05-2016, 10:11 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please make Factory Reset and reflash the phone. Try to find and select Network manually after these actions. If problem will remain - try to write another Cert file. IMEI of Cert file, which You've used can be in "black" list of Network provider. |
05-06-2016, 10:51 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If problem remains the same for all Cert files from the Support Area - You can read Cert file from another compatible model (Cert files compatibility), then try to use it for your phone. |
05-07-2016, 02:15 | #9 (permalink) | |
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
