05-07-2016, 01:49 | #1 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1865815 Status: Offline Sonork: 100.1644854 Thanks Meter: 25 | SM-J700M reset FRP fail ----------------------------------------------------------------------------------- To connect SM-J700M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM5 Modelo seleccionado: SM-J700M To put SM-J700M into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.2.5 software version |
The Following User Says Thank You to joseantonio914 For This Useful Post: |
05-07-2016, 11:26 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Hello. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. You can try to reflash the phone with older firmware, then repeat "Reset FRP/Reactivation/EE" operation. |
