GSMSERVER GSM Shop
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 03-10-2015, 21:51   #1 (permalink)
Member: 2179929
Thanks Meter: 34
G900t wipe security not done
Welcome to Octoplus/Octopus Box Samsung software version 1.8.5
To connect SM-G900T phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Go to dial window.
11. Enter "*#9090#" number.
12. Set "Diag config" to "USB" value.
13. Restart phone.
14. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM19
Selected model: SM-G900T
Reading info, please wait...
ADB server killed.
Detected phone model: SM-G900T
Firmware compiled date: Mon Nov 10 14:59:02 KST 2014
PDA version: G900TUVU1CNK2
CSC version: G900TTMB1CNK2
SW version: G900TUVU1CNK2
Phone IMEI: 353300067822269
Phone SN: RV8F90AWGMH
Android version: 4.4.2 (KOT49H)
Reading info...
Mode: Normal
Firmware compiled date: Jul 29 2014
Firmware compiled time: 07:00:00
Firmware released date: Nov 10 2014
Firmware released time: 14:17:26
SW Version: MPSS.DI.2.0.1.c2-00062-M8974AAAAANRZM-
1.01647286.3416.1
Reading QCN...
Send SPC...
Reading mobile property...
Mobile property read successfully
Reading feature mask...
Feature mask read successfully
Reading roaming list 0
Reading roaming list 0 read successfully
Reading NV items...
NV items read successfully
Reading NV SIM1 items...
NV SIM1 items read successfully
Reading NV SIM2 items...
NV SIM2 items read successfully
Reading NV items...
Reading EFS...
EFS read successfully
Reading provisioning items...
Provisioning items read successfully
Reading QCN done!
Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung
\BACKUP\QCN-SM-G900T-353300067822269-10-03-2015_14-16-
51-.qcn file
Checking Root:
Phone is Rooted.
Reading security backup, please wait...
\BACKUP\Security-SM-G900T-353300067822269-10-03-2015_14-20-
37-.asec file
Wiping EFS...
EFS wipe successfully
Phone will restart now. Please don't disconnect cable!
Searching for a phone. Please wait...
Reading info...
Mode: Normal
1.01647286.3416.1
Send SPC...
SPC send successfully
Writing QCN...
Writing NV items...
NV items write successfully
Writing NV SIM1 items...
NV SIM1 items write successfully
Writing NV SIM2 items...
NV SIM2 items write successfully
Wrting EFS...
EFS write successfully
Writing provisioning items...
Provisioning items write successfully.
Writing QCN done
Wipe security successfully complete.
Selected file: C:\Users\baraa\Downloads\Cert-SM-G900T_
352558067456419_00000000000.cert
ADB server killed.
Checking Root:
Phone is Rooted.
Checking Certificate file...
Certificate file successfully checked
Writing Certificate...
Phone connected successfully
Writing new phone IMEI...
Writing Certificate failed
Reading info...
Mode: Normal
1.01647286.3416.1
Reading QCN...
Send SPC...
Reading NV items...
Reading NV items...
Reading EFS...
Reading QCN done!
\BACKUP\QCN-SM-G900T-353300067822269-10-03-2015_14-27-
42-.qcn file
Checking Root:
Phone is Rooted.
\BACKUP\Security-SM-G900T-353300067822269-10-03-2015_14-31-
29-.asec file
Wiping EFS...
Reading info...
Mode: Normal
1.01647286.3416.1
Send SPC...
Writing QCN...
Writing NV items...
Wrting EFS...
Writing QCN done
Can't kill external ADB references. Please, close all programs that use
ADB server.
ADB server killed.
ADB server killed.
Please, press "OK" button on the phone to allow USB debugging..
Reading info...
Mode: Normal
1.01647286.3416.1
Reading QCN...
Send SPC...
Reading NV items...
Reading NV items...
Reading EFS...
Reading QCN done!
\BACKUP\QCN-SM-G900T-353300067822269-10-03-2015_14-41-
55-.qcn file
Checking Root:
Phone is Rooted.
\BACKUP\Security-SM-G900T-353300067822269-10-03-2015_14-45-
49-.asec file
Wiping EFS...
as you can see i have done wipe security more then one time . phone still has the same IMEI . and the last time the swftwaer stopped at wiping EFS..
i have factory reset and did all that still have the same problem ?
Old 03-10-2015, 21:55   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 25,307
Hello.
Please Make Factory Reset and Wipe Cache partition, reflash the phone with another firmware and try to perform "Wipe Security" again.
Old 03-10-2015, 22:00   #3 (permalink)
Member: 2179929
Thanks Meter: 34
hello . as i said the first time , i have done all that already . no change . still getting the same error . same imei or stopping at wiping EFS
any solution ?
Old 03-11-2015, 00:18   #4 (permalink)
Member: 2179929
Thanks Meter: 34
hello team . this is the phone number 5 its giving me the same probilem !!
G900T N910V N910T !!!
can i get some help ??
Old 03-11-2015, 07:28   #5 (permalink)
Member: 1146942
Sonork: 100.1587278
You can try to wipe Security/EFS via phone's menu. Try to wipe Security/EFS from the phone's menu, do the next:
1. Write any firmware (don't root the phone after, phone should be unrooted, this is important).
2. Type *#9090#.
3. Type at rigth corner MENU + select "Back".
4. Typy at rigth corner MENU + input Q.
5. Type at rigth croner MENU + input 0000.
Look this video manual: https://www.youtube.com/watch?v=1DtPT2MmNhg.
Old 03-11-2015, 22:38   #6 (permalink)
Member: 2179929
Thanks Meter: 34
this option its not supported for G900T .
Old 03-12-2015, 03:41   #7 (permalink)
Member: 1298793
Thanks Meter: 21
hi , i had the same problem with s5 and note 4
galaxy s5 , if imei remain the same here is the step to fix it
1- phone must not be rooted at this moment
2- do factory reset , wipe cache
3- put the phone in download mode- reinstall software latest recomended
4- root the phone with auto root , odin
5- please make sure usb cable is connected directly to the pc, recomended port (back)
6 - try to do the process - phone display put it in 10 minutes
7- if that dont work replace usb cable .
8- drink a beer ()
Old 03-12-2015, 03:43   #8 (permalink)
Member: 1298793
Thanks Meter: 21
By the way - wiping efs start dont let the display to shut off
use the phone while its wiping efs that help me alot too
Old 03-12-2015, 08:12   #9 (permalink)
Member: 2179929
Thanks Meter: 34
thanks but i have done all that already .
imei remain the same .
there's in option called stay awake you can use for the screen to stay on .
Old 05-07-2016, 03:47   #10 (permalink)
Member: 2227401
so no one know how to fix this problem?
Old 05-07-2016, 11:32   #11 (permalink)
Member: 1146942
Sonork: 100.1587278
You can try to use solutions, suggested in previous posts. Also You can use "Reset MSL"/"Fast Reset MSL" operation instead of "Wipe Security" now.
Page generated in 0.34901 seconds with 7 queries
