09-07-2021, 14:47 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: africa mali
Member: 2098907 Status: Offline Thanks Meter: 154 | g920f ulock failed [Answered] INFO : 07/09/2021 12:04:17 > Set up system language English (file: English.ini) INFO : 07/09/2021 12:04:17 > Welcome to Octoplus Box Samsung software version 3.0.6.0 INFO : 07/09/2021 12:04:17 > Card S/N : 00004A09 INFO : 07/09/2021 12:04:19 > ----------------------------------------------------------------------------------- INFO : 07/09/2021 12:04:19 > To connect GT-I9100 phone you have to perform the following steps: INFO : 07/09/2021 12:04:19 > 1. Disconnect USB cable from phone. INFO : 07/09/2021 12:04:19 > 2. Go to Menu->Settings->Applications->Development. INFO : 07/09/2021 12:04:19 > 3. Turn on "USB Debugging" option. INFO : 07/09/2021 12:04:19 > 4. When message is appear press "Yes". INFO : 07/09/2021 12:04:19 > 5. Go to dial window. INFO : 07/09/2021 12:04:19 > 6. Enter "*#7284#" number. INFO : 07/09/2021 12:04:19 > 7. Set "USB" radio button to "PDA" value. INFO : 07/09/2021 12:04:19 > 8. Press Home button. INFO : 07/09/2021 12:04:19 > 9. Go to dial window. INFO : 07/09/2021 12:04:19 > 10. Enter "*#9090# or *#0808#" number. INFO : 07/09/2021 12:04:19 > 11. Set "Diag config" to "USB" value. INFO : 07/09/2021 12:04:19 > 12. Restart phone. INFO : 07/09/2021 12:04:19 > 13. Press "Read Info" in software. INFO : 07/09/2021 12:04:46 > ----------------------------------------------------------------------------------- INFO : 07/09/2021 12:04:46 > To connect SM-G920F phone you have to perform the following steps: INFO : 07/09/2021 12:04:46 > 1. Disconnect USB cable from phone. INFO : 07/09/2021 12:04:46 > 2. Go to Menu->Settings->More->About Device. INFO : 07/09/2021 12:04:46 > 3. Tap on "Build number" 7 times to enable developer options. INFO : 07/09/2021 12:04:46 > 4. Go to Menu->Settings->More->Developer options. INFO : 07/09/2021 12:04:46 > 5. Turn on "USB Debugging" option. INFO : 07/09/2021 12:06:45 > ----------------------------------------------------------------------------------- INFO : 07/09/2021 12:06:50 > Work ID: 0000000001801666 INFO : 07/09/2021 12:06:52 > Platform: Samsung Android INFO : 07/09/2021 12:06:52 > Selected port: INFO : 07/09/2021 12:06:52 > Selected model: SM-G920F INFO : 07/09/2021 12:06:52 > Operation: Read Codes - General INFO : 07/09/2021 12:06:57 > Detected phone model: SM-G920F INFO : 07/09/2021 12:06:57 > Firmware compiled date: Sat Dec 3 12:18:27 KST 2016 INFO : 07/09/2021 12:06:57 > PDA version: G920FXXU5DPL4 INFO : 07/09/2021 12:06:57 > CSC version: G920FDDX5DPL1 INFO : 07/09/2021 12:06:57 > SW version: G920TUVS6FRC1 INFO : 07/09/2021 12:06:57 > Build number: UNKNOWN INFO : 07/09/2021 12:06:57 > Phone SN: R58GB2BWWTD INFO : 07/09/2021 12:06:57 > Android version: 6.0.1 (MMB29K) INFO : 07/09/2021 12:06:57 > Sales code: DTM INFO : 07/09/2021 12:06:57 > Country: Germany INFO : 07/09/2021 12:06:57 > HW platform: exynos5 INFO : 07/09/2021 12:06:57 > HW Chip: exynos7420 INFO : 07/09/2021 12:06:57 > HW Modem: SHANNON333 INFO : 07/09/2021 12:06:57 > Security patch level: 2016-11-01 INFO : 07/09/2021 12:06:57 > Warranty Void: 1 INFO : 07/09/2021 12:06:57 > SIM 1 status: network locked INFO : 07/09/2021 12:06:57 > Codename: zerofltexx INFO : 07/09/2021 12:06:57 > Checking Root: INFO : 07/09/2021 12:07:02 > Phone is Rooted. INFO : 07/09/2021 12:07:02 > Initializing exploit... INFO : 07/09/2021 12:07:19 > OK INFO : 07/09/2021 12:07:28 > Executing exploit... ERROR : 07/09/2021 12:08:27 > Executing exploit failed INFO : 07/09/2021 12:08:27 > Initializing exploit... INFO : 07/09/2021 12:08:52 > Executing exploit... INFO : 07/09/2021 12:10:09 > Exploit has been executed successfully ERROR : 07/09/2021 12:10:21 > Security is damaged (size error)! ERROR : 07/09/2021 12:10:21 > Read codes failed ERROR : 07/09/2021 12:10:21 > MyExceptionEIdSocketErrorSocket Error # 10054 Connection reset by peer. |
09-07-2021, 14:54 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please, do Data Factory Reset, download and install latest software version 3.0.6.2 then repeat Unlock operation and post here result. |
