G920F write cert failed IMEI problem Platform: Samsung Android Selected port: COM20 Selected model: SM-G920F Searching for a phone. Please wait... Phone found. Detected phone model: SM-G920F Firmware compiled date: Thu May 19 19:08:54 KST 2016 PDA version: G920FXXU3DPER CSC version: G920FOJV3DPF3 SW version: unknown Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XSG Country: UAE HW platform: exynos5 HW Chip: exynos7420 HW Modem: unknown Codename: zerofltexx Performed by 2.3.2 software version |
Hello, Loock here: Quote:
If is all ok try to write other time the Cert file. Use this same Version of BUILD: Quote:
Br allumts |
Hello. As You can see from Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair EFS" and "Write Cert" operations. It is not possible to repair IMEI, if phone's modem part is damaged. If after writing of all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). |
i flashed it by its original flash file then i did repair efs ------------------------------------ Platform: Samsung Android Selected port: COM6 Selected model: SM-G920F To put SM-G920F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully Performed by 2.3.2 software version ------------------------------------------------ then info Platform: Samsung Android Selected port: COM20 Selected model: SM-G920F Reading info, please wait... Detected phone model: SM-G920F Firmware compiled date: Tue Jul 5 17:07:18 KST 2016 PDA version: G920FXXS4DPG4 CSC version: G920FOJV3DPC1 SW version: G920FXXS4DPG3 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XSG Country: UAE HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Codename: zerofltexx Performed by 2.3.2 software version -------------------------------------------------- but still have a problem when insert sim card its got Emergency Calls Only/ No service and i cant make calls i tried to write new cert file from support area its got me write certificate failed ---------------------- i did Repair Security/Wipe Security then did write cert its got me write certificate failed again ???????????????????? any solution ?????? ?????????????????????? |
Please do the next: 1. Write first Security backup, which You have, back into the phone. 2. Remove SIM card from the phone. 3. Repeat "Write Cert" operation. Post here full Software log of your actions. |
Platform: Samsung Android Selected port: COM20 Selected model: SM-G920F Selected file: D:\OCTOPUS\G920F\cert-sm-g920f_359845065504586 _rf8g41fbddb.cert Detected phone model: SM-G920F Firmware compiled date: Tue Jul 5 17:07:18 KST 2016 PDA version: G920FXXS4DPG4 CSC version: G920FOJV3DPC1 SW version: G920FXXS4DPG3 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: XSG Country: UAE HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Codename: zerofltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G920F-Unknown02-08-2016_20-01-45-.asec file Checking Certificate file... Certificate file successfully checked Deactivating MSL... Executing exploit... Exploit has been executed successfully Security is damaged Writing Certificate failed |
For you understand Good, you Had first this BUILD of FW: Quote:
NOW YOU HAVE "NEW SECURITY" BUILD FW and is Damaged. Try to Write the Very FIRST Security BKP back and loock if can write CERT...i Doubt Br allumts |
Firmware compiled date: Thu May 19 19:08:54 KST 2016 was have a problem unknown baseband i tried repair and reset efs but no way that is why i updated to Firmware compiled date: Tue Jul 5 17:07:18 KST 2016 its okay for baseband but have a problem on network now i still cant find any solution |
Please perform "Repair Security" operation, then try to write a Cert file again. Post here the result and full Software log of your actions. |
i did Repair security its done but when do write cert baseband back again to unknown and got me failed |
problem Quote:
Please upload the following files to any file-sharing service: 1. Security backup of the phone. You can make a backup via "Read Security" operation. 2. *.log and *.logx files of performed operations. Files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. Post here download link for these 3 files and we will check what causes the problem. |
I'm sorry becouse cannot explain all step by step, (any Fw is different) i have need phone in my hands and manage this, but can be sure that's not easy, all issue is in New Samsung Fw of Jul and June.... good luky for our 2 user with same issue :( Anyway next Sansung with New Build of Fw i will try for do one small tuto Br allumts:) |
