04-02-2017, 17:49 | #1 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2678833 Status: Offline Thanks Meter: 0 | Change Imei Sam S7 I wanted to ask how to proceed to change IMEI or unlock the phone? where can i get an appropriate certificate? |
04-02-2017, 18:31 | #2 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,346 | Hello, First of all read here: http://forum.gsmhosting.com/vbb/f684...hones-2160046/ Then you can only do "Repair Network" from Sw, but if you Update or Reset phone, must need of repeat the work. Br allumts |
04-02-2017, 19:46 | #4 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,346 | Can post here that have solved with "Repair Network" instead of write in Pm. Anyway, for you and All, it's NOT solution definive, this is only Temporary Solution, if RESET or Update FW, phone Lost the Network other time!!! BR allumts |
04-03-2017, 08:01 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,438 | Hello. You can use only backup of phone's original Cert file for "Write Cert" operation for Galaxy S7 phones. You can also use standard "Repair IMEI" operation, which requires to manually enter correct IMEI. |
04-03-2017, 13:30 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,438 | Please post here full Software logs of operations, which You've performed with the phone. You can use only backup of phone's original Cert file for "Write Cert" operation for Galaxy S7 phones. |
04-03-2017, 13:47 | #13 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,346 | Quote:
Quindi DIMENTICA scrittura di Altri CERT, unica soluzione, Con relativi BUG, per KNOX a 0X1 e' questa: Scrittura Imei, (any Number) e REPAIR NETWORK. ENGLISH: Hey, we clarify one thing, you have the KNOX TRIPPED to "WARRANTY VOID 1" So do not talk about CERT because you cannnot write any other cert, you can only write back the original, (in b.List in this case). So FORGET writing Other CERT, unique solution, with its BUG, for KNOX to 0X1 Is this: Write IMEI, (any number) and REPAIR NETWORK. P.D. NOT EXISTE any Tool or Box that Allow of Write Other CERT with KNOX to "WARRANTY VOID 1" IF you Will Haven't Touched SOLUTION Existe, but only for KNOX to "WARRANTY VOID 0" (0X000)!!! BR | |
04-03-2017, 13:48 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,438 | We are not aware of services provided by other tools. Once again, You can use only backup of phone's original Cert file for "Write Cert" operation for Galaxy S7 phones. |
