07-12-2017, 11:01 | #1 (permalink) |
No Life Poster Join Date: Apr 2017 Location: earth
Member: 2711085 Status: Offline Thanks Meter: 183 | g925f samsung account not done latest update Selected port: COM12 Selected model: SM-G925F Please put the phone into Download Mode and connect USB cable. Waiting for phone... Reading PIT... PIT was read successfully. Searching for UART interface.. COM3 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Resetting FRP lock.. FRP / Reactivation lock is successfully reseted! Performed by 2.5.6 Software version. |
07-12-2017, 11:10 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Hello. Yes, we know about this problem and research it. In some devices Samsung lock not reset with this procedure. As soon as we research the problem we will contact You. To reset Samsung Account You can try to do the following: 1. Create a new Samsung account (via PC or via another phone). You should have a working Samsung Account. 2. Perform the Reset FRP/ Reactivation operation. 3. When the phone will ask you to enter Samsung account data - enter Samsung account data, which you have created earlier. 4. Restart the phone and connect it to Wi-Fi. 5. Go to https://findmymobile.samsung.com/ and log in with the username and password (which you have created earlier). There you have to select the phone that was just added to account, select "Unlock my device" and "Unlock Reactivation lock". 6. Restart the phone and check whether account is reseted. |
The Following 3 Users Say Thank You to Octopus box For This Useful Post: |
07-12-2017, 15:59 | #3 (permalink) | |
Major Poster Join Date: Oct 2016
Member: 2635482 Status: Offline Thanks Meter: 13 | Quote:
07-14-2017, 10:30 | #4 (permalink) | |
Freak Poster Join Date: Dec 2009 Location: UK. Worcester Age: 35
Member: 1176876 Status: Offline Sonork: 100.1607051 Thanks Meter: 154 | Quote:
This solution worked for me. Thanks Octopus team. Just one thing, after u perform frp reset with new method,conect to wifi, when phone asks for samsung details and u type in the your or freshly created account it will say "processing failed" but dont worry just go to https://findmymobile.samsung.com/ and do what needs to be done. Last edited by Thorenzz; 07-14-2017 at 10:37. | |
The Following 3 Users Say Thank You to Thorenzz For This Useful Post: |
07-15-2017, 12:15 | #5 (permalink) |
No Life Poster Join Date: Dec 2000 Location: las palmas ,spain
Member: 2800 Status: Offline Thanks Meter: 47 | I'm facing same problem with samsung account with g925f,i try this solution but when i put i get error,and in findmymobile i can see my phone,but i cant see this new one i try to register.I have got S6 but dont see the S6 edge. |
07-15-2017, 12:35 | #6 (permalink) |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Try this method by gurgling the video https://www.youtube.com/watch?v=Mf54lpj6Uss |
07-20-2017, 13:42 | #9 (permalink) | |
No Life Poster Join Date: Oct 2005
Member: 194907 Status: Offline Thanks Meter: 114 | Quote:
frp okey but not disable samsung account Platform: Samsung Android INFO : 20.07.2017 14:48:05 > Selected port: COM3 INFO : 20.07.2017 14:48:05 > Selected model: SM-G925I WARN : 20.07.2017 14:48:05 > Please put the phone into Download Mode and connect USB cable. INFO : 20.07.2017 14:48:05 > Waiting for phone... INFO : 20.07.2017 14:48:05 > Reading PIT... INFO : 20.07.2017 14:48:05 > PIT was read successfully. INFO : 20.07.2017 14:48:05 > Searching for UART interface.. INFO : 20.07.2017 14:48:05 > COM7 WARN : 20.07.2017 14:48:05 > Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds INFO : 20.07.2017 14:48:05 > Searching for device. Please wait... INFO : 20.07.2017 14:48:21 > Resetting FRP lock.. WARN : 20.07.2017 14:48:22 > FRP / Reactivation lock is successfully reseted! INFO : 20.07.2017 14:48:22 > Performed by 2.5.6 Software version. | |
07-20-2017, 15:04 | #11 (permalink) |
Member: 194907 Status: Offline Thanks Meter: 114 | Phone factory reset manuel .I have samsung account 2- and octopus box FRP / Reactivation lock is successfully okey 3-without connected samsung accound phone write and fail 4- phone restart conected wifi and ı samsung account password invalid ıd or pasword: forgot your ID or password 5-how to go https://findmymobile.samsung.com/ adres phone only ACCOUNT INFO RECOVERY http//account .samsung .com For your security your browser cant be opened from this screen phone Sm-G925I android 7.0 B:R |
07-20-2017, 15:15 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | You need to perform "Reset FRP/Reactivation/EE" operation using 1st method "Writing patched UserData partition". After this follow described above steps 3-6. |
07-20-2017, 15:27 | #13 (permalink) | |
Welcome to Octoplus/Octopus Box Samsung software version 2.5.6 ----------------------------------------------------------------------------------- To connect SM-G925I phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G925I Reset FRP/ Reactivation lock operation for SM-G925I will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-G925I into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. Writing Firmware Failed Operation was failed! Performed by 2.5.6 Software version. | |
07-20-2017, 15:34 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | If error occurs after, or during writing of a custom section - most likely phone has one of the newer firmwares. In such case You need to write older by release date firmware, to be able to use this method of Reactivation Lock removal. If You manage to write an older firmware - repeat "Reset FRP/Reactivation/EE" operation. Otherwise reflash the phone with an original firmware to restore it to initial condition. |
07-21-2017, 08:15 | #15 (permalink) | |
Phone account samsung add not ticket how to solve ? | |
