10-28-2020, 22:27 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | g925p write cert failed Card S/N : 300098656 ----------------------------------------------------------------------------------- To connect SM-N900 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-N900 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-G925P phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Work ID: 00000000001CD4BE Platform: Samsung Android Selected port: COM10 Selected model: SM-G925P Operation: Write Cert Selected file: D:\g925p\cert SM-G925P-G925V-G9250-KEY-ID-0449_ 354207070241305\SM-G925P-G925V-G9250-KEY-ID-0449_ 354207070241305.cert Please, press "OK" button on the phone to allow USB debugging. Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-G925P Firmware compiled date: Wed Jan 10 17:09:53 KST 2018 PDA version: G925PVPS4DRA2 CSC version: G925PSPT4DRA2 SW version: G925PVPS4DRA2 Build number: Phone SN: 00000000000 Android version: 7.0 (NRD90M) Sales code: XAS Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: MDM9635M Security patch level: 2018-01-01 Warranty Void: 1 SIM 1 status: absent Codename: zeroltespr Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Writing Certificate failed Performed by 3.0.0.5 Software version. ----------------------------------------------------------------------------------- Work ID: 00000000001CD503 Platform: Samsung Android Selected port: COM10 Selected model: SM-G925P Operation: Write Cert Selected file: D:\g925p\New folder\SM-G925P_35339004181137 _R28G326HXAZ\SM-G925P_35339004181137_R28G326HXAZ.cert Detected phone model: SM-G925P Firmware compiled date: Wed Jan 10 17:09:53 KST 2018 PDA version: G925PVPS4DRA2 CSC version: G925PSPT4DRA2 SW version: G925PVPS4DRA2 Build number: Phone SN: 00000000000 Android version: 7.0 (NRD90M) Sales code: XAS Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: MDM9635M Security patch level: 2018-01-01 Warranty Void: 1 SIM 1 status: absent Codename: zeroltespr Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Writing Certificate failed Performed by 3.0.0.5 Software version. |
