02-11-2021, 15:37 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | g930w8 imei change error why? [Answered] Card S/N : 0001632D ----------------------------------------------------------------------------------- To connect SM-G7102 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G930W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Work ID: 000000000091AC09 Platform: Samsung Android Selected port: COM3 Selected model: SM-G930W8 Operation: Read Cert Please, press "OK" button on the phone to allow USB debugging. Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-G930W8 Firmware compiled date: Fri Sep 11 12:37:42 KST 2020 PDA version: G930W8VLS8CTI1 CSC version: G930W8OYA8CTI1 SW version: G930W8VLS8CTI1 Build number: QB16815728 Phone SN: R58H9281ZQN Android version: 8.0.0 (R16NW) Sales code: FMC Country: Canada HW platform: exynos5 HW Chip: exynos8890 HW Modem: SHANNON335 Security patch level: 2020-09-01 Warranty Void: 1 SIM 1 status: ready Codename: heroltebmc Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G930W8-R58H9281ZQN-11-02-2021_06-19- 46-.asec file Connecting to modem port... Found phone on COM19 Reading data from phone... Could not read data from modem port, trying with exploit.. Initializing exploit... Executing exploit... Exploit has been executed successfully Reading Certificate... Checking Certificate file... Phone KeyID: 870 Certificate file successfully checked Certificate read successfully Performed by 3.0.1.0 Software version. ----------------------------------------------------------------------------------- Work ID: 000000000091ADED Platform: Samsung Android Selected port: COM19 Selected model: SM-G930W8 Operation: Read security Proper android device not found. Make sure that "USB debug" option on the device is turned on. Reading security failed. Performed by 3.0.1.0 Software version. ----------------------------------------------------------------------------------- Work ID: 000000000091AE10 Platform: Samsung Android Selected port: COM19 Selected model: SM-G930W8 Operation: Read security Detected phone model: SM-G930W8 Firmware compiled date: Fri Sep 11 12:37:42 KST 2020 PDA version: G930W8VLS8CTI1 CSC version: G930W8OYA8CTI1 SW version: G930W8VLS8CTI1 Build number: QB16815728 Phone SN: R58H9281ZQN Android version: 8.0.0 (R16NW) Sales code: FMC Country: Canada HW platform: exynos5 HW Chip: exynos8890 HW Modem: SHANNON335 Security patch level: 2020-09-01 Warranty Void: 1 SIM 1 status: ready Codename: heroltebmc Checking Root: Phone is Rooted. Reading security backup, please wait... Security read successfully. Performed by 3.0.1.0 Software version. ----------------------------------------------------------------------------------- Work ID: 000000000091AE72 Platform: Samsung Android Selected port: COM19 Selected model: SM-G930W8 Operation: Read EFS Detected phone model: SM-G930W8 Firmware compiled date: Fri Sep 11 12:37:42 KST 2020 PDA version: G930W8VLS8CTI1 CSC version: G930W8OYA8CTI1 SW version: G930W8VLS8CTI1 Build number: QB16815728 Phone SN: R58H9281ZQN Android version: 8.0.0 (R16NW) Sales code: FMC Country: Canada HW platform: exynos5 HW Chip: exynos8890 HW Modem: SHANNON335 Security patch level: 2020-09-01 Warranty Void: 1 SIM 1 status: ready Codename: heroltebmc Checking Root: Phone is Rooted. Reading EFS, please wait... EFS read successfully. Performed by 3.0.1.0 Software version. ----------------------------------------------------------------------------------- Work ID: 000000000091B223 Platform: Samsung Android Selected port: COM19 Selected model: SM-G930W8 Operation: Repair IMEI A Detected phone model: SM-G930W8 Firmware compiled date: Fri Sep 11 12:37:42 KST 2020 PDA version: G930W8VLS8CTI1 CSC version: G930W8OYA8CTI1 SW version: G930W8VLS8CTI1 Build number: QB16815728 Phone SN: R58H9281ZQN Android version: 8.0.0 (R16NW) Sales code: FMC Country: Canada HW platform: exynos5 HW Chip: exynos8890 HW Modem: SHANNON335 Security patch level: 2020-09-01 Warranty Void: 1 SIM 1 status: ready Codename: heroltebmc Checking root...OK Checking device status...OK Phone will restart now. Please don't disconnect cable! Rebooting phone...OK Searching for ADB device...OK Checking root...OK Connecting to server...OK Checking smart card...OK Username: Authorizing...failed Login error: Wrong username! Write IMEI failed Performed by 3.0.1.0 Software version. |
02-11-2021, 16:17 | #2 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,141 | Hello. Please enter correct Username and password, then repeat the operation once again. Quote:
