10-08-2016, 01:35 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: Spacy's Mobile Service Jamaica
Member: 1300324 Status: Offline Sonork: Spacymobileservice Thanks Meter: 118 | G935P brick after using combination File The combination file g935p_g935aucu2apf1_ etc, now the phone not taking no stock, nor other files, i need fix for flashing bad file from octopus support. |
10-08-2016, 01:41 | #2 (permalink) |
Member: 1300324 Status: Offline Sonork: Spacymobileservice Thanks Meter: 118 | The error am getting when trying to flash with odin i got is Odin protocol version error, i use odin 3.12 and its the same error i recieve |
10-08-2016, 17:27 | #7 (permalink) | |
Member: 1300324 Status: Offline Sonork: Spacymobileservice Thanks Meter: 118 | Quote:
INFO : 10/7/2016 5:21:56 PM > Set up system language English (file: English.ini) INFO : 10/7/2016 5:21:56 PM > Welcome to Octoplus/Octopus Box Samsung software version 2.3.7 INFO : 10/7/2016 5:22:03 PM > ----------------------------------------------------------------------------------- INFO : 10/7/2016 5:22:03 PM > To connect SM-G850M phone you have to perform the following steps: INFO : 10/7/2016 5:22:03 PM > 1. Disconnect USB cable from phone. INFO : 10/7/2016 5:22:03 PM > 2. Go to Menu->Settings->More->About Device. INFO : 10/7/2016 5:22:03 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 10/7/2016 5:22:03 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 10/7/2016 5:22:03 PM > 5. Turn on "USB Debugging" option. INFO : 10/7/2016 6:03:29 PM > ----------------------------------------------------------------------------------- INFO : 10/7/2016 6:03:29 PM > To connect SM-G935P phone you have to perform the following steps: INFO : 10/7/2016 6:03:29 PM > 1. Disconnect USB cable from phone. INFO : 10/7/2016 6:03:29 PM > 2. Go to Menu->Settings->More->About Device. INFO : 10/7/2016 6:03:29 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 10/7/2016 6:03:29 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 10/7/2016 6:03:29 PM > 5. Turn on "USB Debugging" option. INFO : 10/7/2016 6:03:37 PM > Selected firmware file: combination_fa60_g935p_g935aucu2apf1_cl7990385_qb9 797158.oct WARN : 10/7/2016 6:03:41 PM > Please put the phone into Download Mode and connect USB cable. WARN : 10/7/2016 6:03:41 PM > To put SM-G935P into Download Mode, You have to perform the following steps: WARN : 10/7/2016 6:03:41 PM > 1. Reconnect the battery. WARN : 10/7/2016 6:03:41 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 10/7/2016 6:03:41 PM > 3. When phone turns on, press "Volume+" key. INFO : 10/7/2016 6:03:41 PM > Found phone on INFO : 10/7/2016 6:03:41 PM > Firmware write started. INFO : 10/7/2016 6:03:41 PM > Writing ABOOT section... INFO : 10/7/2016 6:03:43 PM > ABOOT section has been written successfully. INFO : 10/7/2016 6:03:43 PM > Writing LKSECAPP section... INFO : 10/7/2016 6:03:45 PM > LKSECAPP section has been written successfully. INFO : 10/7/2016 6:03:45 PM > Writing XBL section... INFO : 10/7/2016 6:03:48 PM > XBL section has been written successfully. INFO : 10/7/2016 6:03:48 PM > Writing TZ section... INFO : 10/7/2016 6:03:50 PM > TZ section has been written successfully. INFO : 10/7/2016 6:03:50 PM > Writing HYP section... INFO : 10/7/2016 6:03:52 PM > HYP section has been written successfully. INFO : 10/7/2016 6:03:52 PM > Writing DEVCFG section... INFO : 10/7/2016 6:03:54 PM > DEVCFG section has been written successfully. INFO : 10/7/2016 6:03:54 PM > Writing PMIC section... INFO : 10/7/2016 6:03:56 PM > PMIC section has been written successfully. INFO : 10/7/2016 6:03:56 PM > Writing RPM section... INFO : 10/7/2016 6:03:58 PM > RPM section has been written successfully. INFO : 10/7/2016 6:03:58 PM > Writing CMNLIB section... INFO : 10/7/2016 6:04:00 PM > CMNLIB section has been written successfully. INFO : 10/7/2016 6:04:00 PM > Writing KEYMASTER section... INFO : 10/7/2016 6:04:02 PM > KEYMASTER section has been written successfully. INFO : 10/7/2016 6:04:02 PM > Writing APDP section... INFO : 10/7/2016 6:04:05 PM > APDP section has been written successfully. INFO : 10/7/2016 6:04:05 PM > Writing MSADP section... INFO : 10/7/2016 6:04:07 PM > MSADP section has been written successfully. INFO : 10/7/2016 6:04:07 PM > Writing CMNLIB64 section... INFO : 10/7/2016 6:04:09 PM > CMNLIB64 section has been written successfully. INFO : 10/7/2016 6:04:09 PM > Writing SEC section... INFO : 10/7/2016 6:04:11 PM > SEC section has been written successfully. INFO : 10/7/2016 6:04:11 PM > Writing APNHLOS section... INFO : 10/7/2016 6:04:14 PM > APNHLOS section has been written successfully. INFO : 10/7/2016 6:04:14 PM > Writing BOOT section... INFO : 10/7/2016 6:04:17 PM > BOOT section has been written successfully. INFO : 10/7/2016 6:04:17 PM > Writing RECOVERY section... INFO : 10/7/2016 6:04:21 PM > RECOVERY section has been written successfully. INFO : 10/7/2016 6:04:21 PM > Writing SYSTEM section... ERROR : 10/7/2016 6:04:23 PM > Writing Firmware Failed INFO : 10/7/2016 6:04:23 PM > Performed by 2.3.7 Software version. WARN : 10/7/2016 6:05:24 PM > Please put the phone into Download Mode and connect USB cable. WARN : 10/7/2016 6:05:24 PM > To put SM-G935P into Download Mode, You have to perform the following steps: WARN : 10/7/2016 6:05:24 PM > 1. Reconnect the battery. WARN : 10/7/2016 6:05:24 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 10/7/2016 6:05:24 PM > 3. When phone turns on, press "Volume+" key. INFO : 10/7/2016 6:05:26 PM > Found phone on INFO : 10/7/2016 6:05:26 PM > Firmware write started. ERROR : 10/7/2016 6:05:31 PM > Writing Firmware Failed INFO : 10/7/2016 6:05:32 PM > Performed by 2.3.7 Software version. Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\07-10-2016_17-21-45.log" closed (10/7/2016 6:07:26 PM). | |
10-09-2016, 08:56 | #8 (permalink) |
Member: 1300324 Status: Offline Sonork: Spacymobileservice Thanks Meter: 118 | Hello Mr Octopus box Product Supporter, customer waiting to get phone up and running what must i do???? As i already shown the log |
10-09-2016, 14:25 | #10 (permalink) |
Member: 1300324 Status: Offline Sonork: Spacymobileservice Thanks Meter: 118 | My problem solve after hours of researching and experimenting |
The Following User Says Thank You to Jermainegenius For This Useful Post: |
