10-29-2014, 08:02 | #1 (permalink) |
No Life Poster Join Date: Jul 2010 Location: mindanao L-D-S
Member: 1339214 Status: Offline Thanks Meter: 514 | Galaxy s5 sm-g900f unlock ok Welcome to Octoplus/Octopus Box Samsung software version 1.7.3 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G900F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900F Selected file: C:\Users\Jammil\Desktop\Cert-SM-G900F_ 352558067456393-00000000000.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900F Firmware compiled date: Fri Sep 12 14:02:06 KST 2014 PDA version: G900FXXU1ANI4 CSC version: G900FOLB1ANI1 SW version: G900FXXU1ANG8 Phone IMEI: 353748062447880 Phone SN: RF8F50V9X5H Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900F Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900F Firmware compiled date: Fri Sep 12 14:02:06 KST 2014 PDA version: G900FXXU1ANI4 CSC version: G900FOLB1ANI1 SW version: G900FXXU1ANG8 Phone IMEI: 353748062447880 Phone SN: RF8F50V9X5H Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Jun 10 2014 Firmware compiled time: 07:00:00 Firmware released date: Jul 23 2014 Firmware released time: 19:34:35 SW Version: MPSS.DI.2.0.1.c2-00064-M8974AAAAANRZM-1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-G900F-353748062447880-29-10-2014_14-42- 53-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G900F-353748062447880-29-10-2014_14-46- 26-.asec file Wiping EFS... EFS wipe successfully Phone will restart now Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Jun 10 2014 Firmware compiled time: 07:00:00 Firmware released date: Jul 23 2014 Firmware released time: 19:34:35 SW Version: MPSS.DI.2.0.1.c2-00064-M8974AAAAANRZM-1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900F Selected file: C:\Users\Jammil\Desktop\Cert-SM-G900F_ 352558067456393_00000000000.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900F Firmware compiled date: Fri Sep 12 14:02:06 KST 2014 PDA version: G900FXXU1ANI4 CSC version: G900FOLB1ANI1 SW version: G900FXXU1ANG8 Phone IMEI: Unknown Phone SN: RF8F50V9X5H Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now Certificate has been written successfully Please, restart the phone to apply changes |
11-12-2014, 18:25 | #3 (permalink) |
No Life Poster Join Date: Feb 2004 Location: GSM-CLINIQUE.COM, SOUTH COAST Age: 43
Member: 54945 Status: Offline Thanks Meter: 22 | it change IMEI ? pc have stop during procedure and so no cert backup with good imei i just restore a cert found on web but bad imei i need to restore old one how can we do it thanks |
11-12-2014, 18:33 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Write backup of phone's original security back into the phone, it will restore the phone to its initial condition. |
