05-21-2015, 01:30 | #1 (permalink) |
No Life Poster Join Date: Oct 2014 Location: Guatemala
Member: 2273678 Status: Offline Thanks Meter: 293 | Domestic Unlock N900P (Sprint Note 3) You're going to need to download and install SSU (please look for this). Once you install it, run and click the unlock button (do thank Dest for this). After you do that, you're going to need to go into the dial pad and dial *#0011# After that you're going to need to click the menu > key input > Q, menu > back, menu > key input > 0000. Wait for about 20 seconds then a menu will appear. Once the menu appears go to: >UE SETTING & INFO >SETTING >PROTOCOL >GCF >GSM/(E)GPRS/WCDMA GCF ON When that is done exit. Reboot device into bootloader and flash the MJ4 modem partition onto the phone. If all was done correctly, the last thing to do is go to settings and change the mobile networks to Automatic. Enjoy |
08-11-2015, 09:05 | #3 (permalink) |
Major Poster Join Date: Jul 2015
Member: 2432664 Status: Offline Thanks Meter: 3 | I can confirm it works on 4.4.4 just follow the steps below, ty so much for this method, Ive unlocked succesfully over 5 Note 3 from sprint so far, both for international gsmīs and USA carriers. |
The Following User Says Thank You to alexlujan For This Useful Post: |
