08-07-2016, 12:01 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | N910H hang in logo-two files tried-error-why? 5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-N910H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed Performed by 2.3.0 software version tried another below firmware also-no scope N910HXXU1ANK5_N910HUWA1ANK5_PGU_Android_4.4.4.oct same error as above help me |
08-08-2016, 16:39 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,438 | Try to reflash the phone with "N910HXXS2CPC2_N910HOJV2COJ1_ACR_Android_5.1.1 " firmware from the Support Area and pot here the result. |
08-09-2016, 09:06 | #5 (permalink) | |
Member: 946381 Status: Offline Thanks Meter: 150 | Quote:
To connect SM-N910H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: N910HXXS2CPC2_N910HOJV2COJ1 _ACR_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-N910H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... Writing Firmware Failed Performed by 2.3.2 software version is it flash ic problem? | |
08-09-2016, 11:14 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,438 | Please repeat "Write Firmware" operation with enabled "Advanced mode" option. Un-check "Hidden" partition (select all partitions except of "Hidden") in process and continue with writing. |
08-10-2016, 05:22 | #7 (permalink) | |
1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. Performed by 2.3.2 software version now flashing ok-but still in reboot help me | |
