HELP - Samsung Galaxy Note 3 N900A IMEI REPAIR Sorry if this may seem like a stupid questions. I'm pretty new to the whole IMEI repair scene. I've been able to repair the IMEI on S3 and S4. But not the Note 3. I have a Galaxy Note 3 N900A - Rooted Already. I am able to set the USB Settings to DM+MODEM+ADB through *#0808# When I press *#9090# - the phone says DIAG CONFIG Not Support I'm not able to change the "Diag config" to "USB" value ... PLEASE advise on what I need to do so that I can put the phone into Diagnostic Mode. Thank you in advance. |
Platform: Samsung Android Selected port: COM8 Selected model: SM-N900A Mode: Normal Phone model: SM-N900A Firmware compiled date: Oct 17 2013 Firmware compiled time: 16:59:54 Firmware released date: Oct 17 2013 Firmware released time: 16:59:54 SW version: SET_BY_CM Old IMEI: 357572-05-366937-7 New IMEI: 357507-05-000028-3 Creating NVM backup Reading NVM done! Connecting to ADB, please waite... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed USB debug is definitely turned on in Developers Options. Anything else I'm missing here? |
make sure you fellow all the steps 1 by 1 and keep touching the screen on while its going thor the processes dont let the screen shut off keep it on ok.. I just did my N900T.. Repaired it.. all this steps worked for me.. |
Install adb drivers on your pc. After that make sure you accept a prompt on your phone saying that you trust your computer. If you don't do that then octopus won't recognize the phone and you will get an adb error. |
Hello. USB Debugging Mode is not turned on in your device: Quote:
Team when I add my own imei and unlock the n900t.. Sent from my SGH-M919 using Tapatalk |
After perform Unlock operation for SM-N900T, IMEI will be set to service value "35750705000001/0". By performing Repair IMEI operation for SM-N900T, it is possible to repair IMEI to one of the service IMEIs from the list. Currently no solution, how to repair IMEI to original value. |
So only on the listing I can repair the imei, but I can type my own imei.. Can I or I can't. Sent from my SGH-M919 using Tapatalk |
not for unlock need change you original to any super imei of list cant write oroginal imei |
I get a error message saying I will to use the drop down imei.. Sent from my SGH-M919 using Tapatalk |
