Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2011 Location: Manila Age: 33
Member: 1493085 Status: Offline Sonork: n/a Thanks Meter: 88 | [HELP] SM-A260F how to root? [Answered] Work ID: 00000000006A0CEF Platform: Samsung Android Selected port: COM12 Selected model: SM-A260F Operation: Read Codes - Via ADB Detected phone model: SM-A260F Firmware compiled date: Fri Oct 16 17:08:27 KST 2020 PDA version: A260FXXS8ATJ1 CSC version: A260FOJM8ATJ1 SW version: A260FJVS8ATJ1 Build number: QB17136990 Phone SN: RZ8M92493ZH Android version: 8.1.0 (OPR6) Sales code: MID Country: Iraq HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2020-11-01 Warranty Void: 0 SIM 1 status: network locked SIM 2 status: absent Codename: a2coreltejx ----------------------------------------------------------------------------------- Connecting to server .. Username: -------------- Connect to server successfull. Checking smart card... Checking operation...OK Your balance: 100 credits. ----------------------------------------------------------------------------------- Checking Root: Phone is not Rooted. Reading codes...failed Read codes failed Performed by 3.0.1.0 Software version. =============================== i can't found root file, eng modem, downgrade tutorial,- combination firmware ![]() please help. |
![]() | #2 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Oct 2009
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 25,774 | Hello. Unfortunately, we don't provide any root methods or manuals, You need to root your device manually, we recommend You to use EFTSU root method |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
![]() | #3 (permalink) |
Member: 1493085 Status: Offline Sonork: n/a Thanks Meter: 88 | ![]() root : ok input unlock code : ok but phone can't make call : emergency call only pop notification : phone not allowed ===================== log read code ===================== Work ID: 00000000006A3B43 Platform: Samsung Android Selected port: COM13 Selected model: SM-A260F Operation: Read Codes - Any KNOX. Latest Firmwares are supported! Detected phone model: SM-A260F Firmware compiled date: Fri Oct 16 17:08:27 KST 2020 PDA version: A260FXXS8ATJ1 CSC version: A260FOJM8ATJ1 SW version: A260FJVS8ATJ1 Build number: QB17136990 Phone SN: RZ8M92493ZH Android version: 8.1.0 (OPR6) Sales code: MID Country: Iraq HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2020-11-01 Warranty Void: 1 SIM 1 status: network locked SIM 2 status: absent Codename: a2coreltejx Checking root...OK Checking device status...OK Phone will restart now. Please don't disconnect cable! Rebooting phone...OK Searching for ADB device...OK Checking root...OK Connecting to server...OK Checking smart card...OK Username: ---------------- Authorizing...OK Checking balance...OK Your balance: 100 credits. Checking operation...OK Initializing exploit...OK Checking operation...OK Bypassing security 1...OK Bypassing security 2...OK Reseting MSL...OK Reading codes...OK FREEZE: 52001046 NET LOCK: 17556591 SUB LOCK: 00000000 SP LOCK: 00000000 CP LOCK: 00000000 SIM LOCK: 00000000 ===================================== ==================== read info after input unlock code ==================== Work ID: 00000000006A4495 Platform: Samsung Android Selected port: COM13 Selected model: SM-A260F Operation: Reboot Download Detected phone model: SM-A260F Firmware compiled date: Fri Oct 16 17:08:27 KST 2020 PDA version: A260FXXS8ATJ1 CSC version: A260FOJM8ATJ1 SW version: A260FJVS8ATJ1 Build number: QB17136990 Phone SN: RZ8M92493ZH Android version: 8.1.0 (OPR6) Sales code: MID Country: Iraq HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2020-11-01 Warranty Void: 1 SIM 1 status: ready SIM 2 status: absent Codename: a2coreltejx ========================= try restore with this firmware A260FXXS8ATJ1_A260FOJM8ATJ1_MID : - but still not help. ========================= Please put the phone into Download Mode and connect USB cable. To put SM-A260F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing USERDATA section... USERDATA section has been written successfully. Writing VENDOR section... VENDOR section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CP_DEBUG section... CP_DEBUG section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing ODM section... ODM section has been written successfully. Writing OMR section... OMR section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 3.0.1.0 Software version. |
![]() | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 25,774 | The Read Codes operation has nothing to your network, this type of operation is just read out Unlock codes from your device. This could be Software or HW issue, try to reflash your deviec with different firmwares, etc |
![]() | #5 (permalink) | |
Member: 1493085 Status: Offline Sonork: n/a Thanks Meter: 88 | ![]() Quote:
============= this is normal ? | |
