07-10-2021, 09:05 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 1,021 | SM J200F Repair IMI Repair Network EFS Repair successfully Welcome to Octoplus Box Samsung software version 3.0.6.1 Card S/N : 00000E47 ----------------------------------------------------------------------------------- To connect SCL24 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-N5100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-J700M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. Selected AP file: C:\Users\NAVEED PC\Downloads\Compressed \AZ_AUTOROOT_J200F_BULD_AQD2 \AZ_AUTOROOT_J200F_BULD_AQD2.tar Please put the phone into Download Mode and connect USB cable. To put SM-J200F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing CACHE section... CACHE section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Firmware writing successfully completed. Performed by 3.0.6.1 Software version. ----------------------------------------------------------------------------------- Work ID: 00000000013E8EA5 Platform: Samsung Android Selected port: COM16 Selected model: SM-J200F Operation: Repair IMEI A Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-J200F Firmware compiled date: Fri Mar 17 16:22:34 KST 2017 PDA version: J200FXXU3AQC2 CSC version: J200FOJV3AQC1 SW version: J200FXXU3AQC1 Build number: QB5910943 Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Sales code: XSG Country: UAE HW platform: exynos3 HW Chip: exynos3475 HW Modem: SHANNON308 Security patch level: 2017-03-01 Warranty Void: 1 SIM 1 status: absent SIM 2 status: absent Codename: j2ltejv Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-J200F-RF1D45EJGGR-10-07-2021_12-22- 36-.asec file Connecting to modem port... Found phone on COM17 Reading data from phone... Could not read data from modem port, trying with exploit.. Initializing exploit... Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Phone found. Executing exploit... Exploit has been executed successfully New IMEI: 35-------------- Writing new phone IMEI... Please make "Repair Network" operation after reboot! IMEI successfully repaired. Performed by 3.0.6.1 Software version. ----------------------------------------------------------------------------------- Work ID: 00000000013E9056 Platform: Samsung Android Selected port: COM17 Selected model: SM-J200F Operation: Repair IMEI B Detected phone model: SM-J200F Firmware compiled date: Fri Mar 17 16:22:34 KST 2017 PDA version: J200FXXU3AQC2 CSC version: J200FOJV3AQC1 SW version: J200FXXU3AQC1 Build number: QB5910943 Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Sales code: XSG Country: UAE HW platform: exynos3 HW Chip: exynos3475 HW Modem: SHANNON308 Security patch level: 2017-03-01 Warranty Void: 1 SIM 1 status: absent SIM 2 status: absent Codename: j2ltejv Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-J200F-RF1D45EJGGR-10-07-2021_12-31- 17-.asec file Connecting to modem port... Found phone on COM17 Reading data from phone... Could not read data from modem port, trying with exploit.. Initializing exploit... Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Phone found. Executing exploit... Exploit has been executed successfully New IMEI: 357-------------------- Writing new phone IMEI... Please make "Repair Network" operation after reboot! IMEI successfully repaired. Performed by 3.0.6.1 Software version. ----------------------------------------------------------------------------------- Work ID: 00000000013E92D5 Platform: Samsung Android Selected port: COM17 Selected model: SM-J200F Operation: Repair Network Detected phone model: SM-J200F Firmware compiled date: Fri Mar 17 16:22:34 KST 2017 PDA version: J200FXXU3AQC2 CSC version: J200FOJV3AQC1 SW version: J200FXXU3AQC1 Build number: QB5910943 Phone SN: RF1D45EJGGR Android version: 5.1.1 (LMY47X) Sales code: XSG Country: UAE HW platform: exynos3 HW Chip: exynos3475 HW Modem: SHANNON308 Security patch level: 2017-03-01 Warranty Void: 1 SIM 1 status: absent SIM 2 status: ready Codename: j2ltejv Checking Root: Phone is Rooted. Repairing network. Please wait, this can take some time... Network is successfully repaired. Performed by 3.0.6.1 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM17 Selected model: SM-J200F Port is busy To put SM-J200F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Repair EFS was canceled Performed by 3.0.6.1 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM17 Selected model: SM-J200F To put SM-J200F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully Performed by 3.0.6.1 Software version. |
The Following 2 Users Say Thank You to naveedullah0044 For This Useful Post: |
