11-23-2015, 12:23 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | How to unlock SPH-l720 5.0.1 with Octoplus.?? is possible to use this phone in Europe GSM network and another question its need to phone must be rooted before unlocking procedure thx |
11-23-2015, 12:40 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. To connect SPH-L720 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Connect the phone directly to PC. 14. Press "Read Info" in software. Also, You might need to enable CP logging in Recovery Mode, so that phone could be detected by PC. Root is not required for "Unlock" operation. |
11-23-2015, 13:16 | #3 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | i cant enter in diag configuration menu i press *#9090# but my phone not show nothing CP logging is enabled also USB Debugging" option.is on ??what can i do |
11-23-2015, 13:45 | #5 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | i unlocked the phone ,but i dont have network i choose GSM in network specification menu but still searching...... work this phone in europe?????? thx |
11-23-2015, 14:23 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please repeat "Unlock"/"Domestic Unlock" operation, then try to do the next: 1. Dial *#0011# and in the service menu do the following. 2. Click "Menu" then "Key input" then input Q then press "Ok". 3. Click "Menu" then "Back". 4. Click "Menu" then "Key input" then input 0000 then click "Ok". After these steps Hidden menu should open. In Hidden menu, depending on available options, try to do the following: I.
II.
After these actions go to Settings -> Mobile Networks and Set Network Mode to Automatic, or GSM. |
11-24-2015, 10:06 | #9 (permalink) |
Freak Poster Join Date: Jan 2015 Location: Romania
Member: 2332708 Status: Offline Thanks Meter: 7 | downgrade 4.4.2 and unlock octoplus no unlock l720 and l720t android 5.0.1 re flash L720VPUFNG2 root and unlock Last edited by Octopus box; 11-24-2015 at 10:58. |
01-27-2016, 15:38 | #11 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | Platform: Samsung Android Selected port: COM1 Selected model: SPH-L720 Detected phone model: SPH-L720 Firmware compiled date: Tue Apr 21 15:56:06 KST 2015 PDA version: L720VPUGOD2 CSC version: L720SPTGOD2 SW version: L720VPUGOD2 Phone SN: 00000000000 Android version: 5.0.1 (LRX22C) Checking Root: Phone is not Rooted. Installing service app... Unlocking phone... Finalizing... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. still no service what to do next? |
The Following User Says Thank You to asadnow2k For This Useful Post: |
01-27-2016, 15:59 | #13 (permalink) |
Member: 199814 Status: Offline Thanks Meter: 1,960 | Please repeat "Unlock"/"Domestic Unlock" operation, then try to do the next: 1. Dial *#0011# and in the service menu do the following. 2. Click "Menu" then "Key input" then input Q then press "Ok". 3. Click "Menu" then "Back". 4. Click "Menu" then "Key input" then input 0000 then click "Ok". After these steps Hidden menu should open. In Hidden menu, depending on available options, try to do the following: I. Press UMTS Press DEBUG SCREEN Press PHONE CONTROL Press NETWORK CONTROL Set GCF to ON there is no option of GCF on there are some other options.. check on GSM/E/GPRS/WCDMa rel 8 -- rel 7 rel 6 and so on.. what to do next? |
