04-20-2016, 13:46 | #1 (permalink) |
No Life Poster Join Date: Jun 2007
Member: 532257 Status: Offline Sonork: 1624266 Thanks Meter: 64 | j100h after flash set samsung j1 display and ower off Welcome to Octoplus/Octopus Box Samsung software version 2.2.4 ----------------------------------------------------------------------------------- To connect SCL24 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-J100H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: j100hxxu0aoa8_j100hojv0aoa3_lys_android_ 4.4.4.oct Please put the phone into Download Mode and connect USB cable. To put SM-J100H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing system section... system section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing WDSP section... WDSP section has been written successfully. Writing wfixnv2 section... wfixnv2 section has been written successfully. Writing CSC section... CSC section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.2.4 software version |
