Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 12-10-2013, 04:34   #61 (permalink)
Member: 1173425
Thanks Meter: 17
he used the code to unlock his phone, which doesnt do anything to network. Check ur imei in cwta databse if ur phone is blacklisted if it is then it is not going to work in Canada.
Old 12-10-2013, 06:59   #62 (permalink)
Member: 2081685
thanks, you are right, it's blacklisted. ****.
Old 12-10-2013, 08:42   #63 (permalink)
Member: 1173425
Thanks Meter: 17
there are two way u can use ur phone again
1.Send it outside Canada and it will work with other countries
2. change imei (which is ofcourse illegal to do it).
I will recommend to send it outside the Canada other than u r smart enough to make a call for urself
Old 12-10-2013, 15:54   #64 (permalink)
Member: 1754412
Sonork: 100.1620116
Thanks Meter: 27
Originally Posted by sunny80 View Post
Hi,
I am searching for a solution to my "not registered on network" problem.
I have read all these posts, I am having the same issue but I paid $40 for an unlock code online.
I have an i527m on telus and now it is unlocked but does not work. I had it briefly work on Rogers for about 30 seconds. I have rooted but that's all I know. It looks like ALI and Badsha figured this out, is there a possibility of a step by step? How did you guys get the qcn file from each other?
first check the phone on Protect Your Data. Protect Yourself.
Old 12-11-2013, 01:19   #65 (permalink)
Member: 2081685
thanks for your help Badsha, essentially I have lost the value of the phone so I am going to pay the karma forward and post an ad to give the phone back to the rightfull owner if they can tell me the imei number.
I have to be more careful when I buy phones off craigslist.
Old 12-11-2013, 16:08   #66 (permalink)
Member: 1173425
Thanks Meter: 17
Just for the info, once the phone is blacklisted, it cant be undone so there is no point returning the phone bcoz it will be pretty useless for him as well...
Old 12-11-2013, 18:20   #67 (permalink)
Member: 1406187
Thanks Meter: 2
Originally Posted by alifauad79 View Post
Well step by step.. I will try my best.
Downloaded QCN file by rekamyenoM (Special thanks to him)
When I used that QCN file, my IMEI changed to his phone IMEI.
Edited the QCN file by WINHEX, change the IMEI to my IMEI (The IMEI values are written in NV_Item 550) it is written in the format 08, 3A, 75. backward format) and used QPST to apply the new EDITED file. IMEI changed
I knew about these issues so i backed up nvm via qpst and octoplus
when i unlocked the phone same thing happened so tried to re-write the nvm via octoplus which didn't work
then tried to restore to original nvm via qpst but "phone restart fails" thus unable to restore to original
so far have nvm backed up in both version but uable to fix
Old 12-11-2013, 20:34   #68 (permalink)
Member: 1173425
Thanks Meter: 17
Just restart ur phone manually and it will resolve ur problem...
Old 12-12-2013, 00:35   #69 (permalink)
Member: 1754412
Sonork: 100.1620116
Thanks Meter: 27
if you are the owner you can
Old 12-25-2013, 12:22   #70 (permalink)
Member: 2068349
Thanks Meter: 4
Originally Posted by ttn1185 View Post
Yes, it will work. HOWEVER, try the phone again with AT&T sim card. You will notice that the phone will pick up LTE signal and everything, but voice call doesn't work. Only data works.
50% of the Mega I527 I unlocked experience this strange symptom. I wish I had copied the nvm backups from the good unlocked ones before updating the software since that erased the backup folder
I have solved this issue if you need the fix.
Old 12-25-2013, 12:30   #71 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,435
And what is the solution?
Old 12-25-2013, 12:36   #72 (permalink)
Member: 2068349
Thanks Meter: 4
Just change the imei number to one that is not blacklisted.
Old 12-25-2013, 18:03   #73 (permalink)
Member: 1146942
Sonork: 100.1587278
@ nickmatine
Currently we have no solution for this problem. We are ready to buy your phone to research the problem. Our manager will contact You tomorrow.
Old 12-26-2013, 09:27   #74 (permalink)
Member: 2092415
Thanks Meter: 12
Hi,
I have a similar problem, after unlock my galaxy mega i527, I cnat get signal, I tried to write the NVM again(with the backups) and the signal comes only for a few minutes...
Did you find a stable solution?
thanks a lot
Old 12-26-2013, 18:35   #75 (permalink)
Member: 2068349
Thanks Meter: 4
Originally Posted by edro85 View Post
Hi,
thanks a lot
If you write my qcn file to the phone it will work again. The qcn will change your IMEI number, but then just use EFS Pro to change it back.
The Following User Says Thank You to rekamyenoM For This Useful Post:
Page generated in 0.35183 seconds with 8 queries
