Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 05-10-2016, 14:14   #1 (permalink)
flechazo's Avatar
Member: 39250
Thanks Meter: 64
Impossible to remove account google
hi
i try with octopus without success, i try to flash it with diferent firmware without sucess
Welcome to Octoplus/Octopus Box Samsung software version 2.2.5
To connect SM-J700F phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
Selected firmware file: J700FZTU1APA3_J700FZZT1APA3_J700FZTU1APA3_HOME.oct
Please put the phone into Download Mode and connect USB cable.
To put SM-J700F into Download Mode, You have to perform the following steps:
1. Reconnect the battery.
2. Press and hold "Volume-" + "Home" + "Power ON" keys.
3. When phone turns on, press "Volume+" key.
Found phone on
Firmware write started.
Writing BOOTLOADER section...
BOOTLOADER section has been written successfully.
Writing CM section...
CM section has been written successfully.
Writing Firmware Failed
Performed by 2.2.5 software version
Display : sw rev. check fail. device : 2; binary:1
oficial firmware for this phone is :
Product code BRI
PDA J700FZTU1APA3
CSC J700FZZT1APA3
Old 05-10-2016, 14:30   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 26,124
Hello.
Unfortunately currently no stable solution for FRP lock removal for SM-J700F with new firmwares. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares.
You can try to use solution suggested by mr.khudda1234 here: http://forum.gsmhosting.com/vbb/f684...46/index2.html
Another solution was suggested by mr.calvinpower here: http://forum.gsmhosting.com/vbb/f684...oblem-2080233/
Old 05-10-2016, 14:41   #3 (permalink)
flechazo's Avatar
Member: 39250
Thanks Meter: 64
phone dont accept any firmware u can give m a good firmware to ret plz
Product code BRI
PDA J700FZTU1APA3
CSC J700FZZT1APA3
Old 05-10-2016, 15:11   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
Currently we can't say with which firmware exactly You will be able to reflash the phone safely, to be able to remove lock.
Old 05-10-2016, 17:41   #5 (permalink)
flechazo's Avatar
Member: 39250
Thanks Meter: 64
im asking for firmware compatible to flash it i dont need now remove LOCK
Old 05-10-2016, 17:50   #6 (permalink)
Member: 1146942
Sonork: 100.1587278
You can use "J700FXXU2APC4_J700FOJV2APC3_XSG_Android_5.1.1 " firmware from the Support Area.
Old 05-10-2016, 18:12   #7 (permalink)
flechazo's Avatar
Member: 39250
Thanks Meter: 64
all flash file from support is tested Any flash work
Samsung Galaxy J7 (SM-J700F/DH)
Old 05-10-2016, 18:59   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
Please post here full Software log of writing of a "J700FXXU2APC4_J700FOJV2APC3_XSG_Android_5.1.1 " firmware.
Old 05-10-2016, 19:20   #9 (permalink)
flechazo's Avatar
Member: 39250
Thanks Meter: 64
2.2.5
steps:
Selected firmware file: J700FXXU1AOI1_J700FOJV1AOI1
_XSG_Android_5.1.1.oct
following steps:
Found phone on
Old 05-11-2016, 15:04   #10 (permalink)
flechazo's Avatar
Member: 39250
Thanks Meter: 64
im still waiting answer or Currently we dont have solution,
Old 05-11-2016, 15:36   #11 (permalink)
Member: 1146942
Sonork: 100.1587278
Try to write "J700FXXU2APD6_J700FOJV2APD1_TUR_Android_5.1.1 " firmware from the Support Area. This is the latest of available firmwares for SM-J700F.
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.23130 seconds with 7 queries
