02-17-2016, 04:40 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | G355h imei 0000000 Welcome to Octoplus/Octopus Box Samsung software version 2.2.0 ----------------------------------------------------------------------------------- To connect GT-I9305 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Press Home button. 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I9305 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Press Home button. 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I9305 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Press Home button. 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G355H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G355H Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM55 Selected model: SM-G355H Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM55 Selected model: SM-G355H Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM55 Selected model: SM-G355H Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G355H Firmware compiled date: Thu Jun 19 21:04:11 KST 2014 PDA version: G355HXXU0ANFC CSC version: G355HOXE0ANFC SW version: G355HXXU0ANFC Phone IMEI: 000000000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Old IMEI A: 000000000000000 New IMEI A: 3534554466667699 Repairing IMEI. Please wait... Repairing network. Please wait, this can take some time... Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. |
02-17-2016, 05:19 | #2 (permalink) |
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | Welcome to Octoplus/Octopus Box Samsung software version 2.2.0 ----------------------------------------------------------------------------------- To connect SM-G355H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM55 Selected model: SM-G355H Reading info, please wait... Detected phone model: SM-G355H Firmware compiled date: Thu Jun 19 21:04:11 KST 2014 PDA version: G355HXXU0ANFC CSC version: G355HOXE0ANFC SW version: G355HXXU0ANFC Phone IMEI: 000000000000000 Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM55 Selected model: SM-G355H Detected phone model: SM-G355H Firmware compiled date: Thu Jun 19 21:04:11 KST 2014 PDA version: G355HXXU0ANFC CSC version: G355HOXE0ANFC SW version: G355HXXU0ANFC Phone IMEI: 000000000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Old IMEI A: 000000000000000 New IMEI A: 3550670607542499 Repairing IMEI. Please wait... Repairing network. Please wait, this can take some time... Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. |
04-28-2016, 07:24 | #6 (permalink) |
Junior Member Join Date: Apr 2012
Member: 1742595 Status: Offline Thanks Meter: 0 | g355h imei 000000 I have the same case?g355h/ds imei 00000000000 . Please send me EFS!!!! Вас приветствует Octoplus/Octopus Box Samsung software версии 2.2.2 -------------------------------------------- Платформа: Samsung Android Выбранный порт: COM20 Выбранная модель: SM-G355H Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Определена модель телефона: SM-G355H Дата создания прошивки: Sat Sep 6 22:53:18 KST 2014 PDA version: G355HXXU0ANI1 CSC version: G355HOXE0ANI1 Версия программного обеспечения: G355HXXU0ANI1 IMEI телефона: 000000000000000 Android version: 4.4.2 (KOT49H) Performed by 2.2.2 software version ----------------------------------------------------------------------------- Платформа: Samsung Android Выбранный порт: COM20 Выбранная модель: SM-G355H Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Определена модель телефона: SM-G355H Дата создания прошивки: Sat Sep 6 22:53:18 KST 2014 PDA version: G355HXXU0ANI1 CSC version: G355HOXE0ANI1 Версия программного обеспечения: G355HXXU0ANI1 IMEI телефона: 000000000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Old IMEI A: 000000000000000 New IMEI A: 3567530676449188 Repairing IMEI. Please wait... Repairing network. Please wait, this can take some time... Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. Performed by 2.2.2 software version ------------------------------------- But imei still 0000000 Please send me EFS!!!! |
