04-27-2016, 19:05 | #1 (permalink) |
Insane Poster Join Date: Apr 2012 Location: Davie Florida
Member: 1745565 Status: Offline Thanks Meter: 14 | N910T Samsung Account Removal Help It tells me it's currently not supported on octoplus 2.2.5 Sammy here's my log: Code: Welcome to Octoplus/Octopus Box Samsung software version 2.2.5 ----------------------------------------------------------------------------------- To connect SM-N910T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-N910T To put SM-N910T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Reset operation completed! Performed by 2.2.5 software version ----------------------------------------------------------------------------------- To connect SM-N920T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-N920T To put SM-N920T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Reset operation completed! Performed by 2.2.5 software version ----------------------------------------------------------------------------------- To connect SM-N900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-N900T To put SM-N900T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Reset operation completed! Performed by 2.2.5 software version ===================== Last edited by Octopus box; 04-28-2016 at 13:24. |
04-28-2016, 12:30 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Currently Reset Reactivation (Samsung Account) Lock works only for Galaxy S6/S6+ and newer phones. You can try to remove the lock via corresponding service in Octoplus Suite Software. |
04-28-2016, 12:31 | #3 (permalink) | |
Member: 1745565 Status: Offline Thanks Meter: 14 | Quote:
Sent from my SM-N920T using Tapatalk | |
