11-20-2016, 10:30 | #1 (permalink) |
Major Poster Join Date: Aug 2008 Location: Indonesia
Member: 829846 Status: Offline Thanks Meter: 3 | J200g sw rev.check fail devices 2 binary 1 i try to reset frp but nothing change than i use combination file for j200g in suport but its come with such error this is log Performed by 2.3.7 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-J200G into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed any solutions thanks |
The Following User Says Thank You to multicom For This Useful Post: |
11-20-2016, 10:41 | #2 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | Quote:
The Following User Says Thank You to gsaara For This Useful Post: |
11-20-2016, 11:00 | #4 (permalink) | |
2.02 Gb2015-12-311244 J200GDDU1AOJ3_J200GODD1AOJ3_J200GDDU1AOJ3_Android_ 5.1.1.oct2.02 Gb2015-12-31779 J200GDDU1AOK1_J200GODD1AOK1_J200GDDU1AOK1_Android_ 5.1.1.oct2.03 Gb2015-12-313625 | |
The Following 2 Users Say Thank You to gsaara For This Useful Post: |
11-20-2016, 11:01 | #5 (permalink) |
Member: 1418524 Status: Offline Thanks Meter: 186 | [QUOTE=gsaara;12170952] J200GDDU1AOJ1_J200GODD1AOJ1_SLK_Android_5.1.1.oct |
11-20-2016, 11:10 | #6 (permalink) |
Crazy Poster Join Date: Mar 2011
Member: 1543245 Status: Offline Thanks Meter: 6 | it happens on me also on october security patch cant flash anything (except current patch level or higher) just try to flash combination but just select boot only if fails then only option is server method frp removal... goodluck |
The Following User Says Thank You to Wiki_clouD For This Useful Post: |
11-20-2016, 14:00 | #7 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2016
Member: 2532914 Status: Offline Thanks Meter: 1,154 | The phone is telling you exactly what is wrong. Your phone is on version 2 and you are trying to flash a version 1 binary to it. you need the new version 2 combo file. |
The Following User Says Thank You to markhaines1985 For This Useful Post: |
11-21-2016, 09:04 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. In most cases problem with writing of Combination firmware occurs if it is not compatible with current firmware of the phone. You need to try to write another Combination firmware. Also You can use Factory Reset FRP Service. |
