04-08-2016, 09:28 | #1 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Negros, Philippines
Member: 525940 Status: Offline Thanks Meter: 213 | imei repair problem on n8000 Quote:
this is note 10 tablet gt-n8000 is there any way to use usb only? | |
04-08-2016, 10:51 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | Hello. UART cable is not needed for connection. This problem is already being research. But, as You can see from Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged. | |
08-29-2016, 11:51 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | If after writing of all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). |
08-29-2016, 12:12 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | You can also try to write Full Flash file via eMMC. Full Flash file for this model is available in the Support Area. |
