01-17-2014, 11:32 | #1 (permalink) |
Freak Poster Join Date: Apr 2012 Location: only unlock punjab india
Member: 1745576 Status: Offline Thanks Meter: 12 | i317m not read info in octopus [Solved] octopus team solve my this paroblam plz Code: INFO : 1/17/2014 3:41:11 PM > Welcome to Octoplus/Octopus Box Samsung software version 1.4.5 INFO : 1/17/2014 3:41:24 PM > ----------------------------------------------------------------------------------- INFO : 1/17/2014 3:41:24 PM > To connect SGH-I317M phone you have to perform the following steps: INFO : 1/17/2014 3:41:24 PM > 1. Disconnect USB cable from phone. INFO : 1/17/2014 3:41:24 PM > 2. Go to Menu->Settings->Developer options. INFO : 1/17/2014 3:41:24 PM > 3. Turn on "USB Debugging" option. INFO : 1/17/2014 3:41:24 PM > 4. When message is appear press "Yes". INFO : 1/17/2014 3:41:24 PM > 5. Go to dial window. INFO : 1/17/2014 3:41:24 PM > 6. Enter "*#7284#" number. INFO : 1/17/2014 3:41:24 PM > 7. Set "UART" radio button to "MODEM" value. INFO : 1/17/2014 3:41:24 PM > 8. Go to "Qualcomm USB Settings". INFO : 1/17/2014 3:41:24 PM > 9. Select "RNDIS+DM+MODEM". INFO : 1/17/2014 3:41:24 PM > 10. Close window. INFO : 1/17/2014 3:41:24 PM > 11. Go to dial window. INFO : 1/17/2014 3:41:24 PM > 12. Enter "*#9090#" number. INFO : 1/17/2014 3:41:24 PM > 13. Select "DM/UM over HS-USB". INFO : 1/17/2014 3:41:24 PM > 14. Restart phone. INFO : 1/17/2014 3:41:24 PM > 15. Press "Read Info" in software. INFO : 1/17/2014 3:41:55 PM > ----------------------------------------------------------------------------------- INFO : 1/17/2014 3:41:55 PM > Platform: Samsung Android INFO : 1/17/2014 3:41:55 PM > Selected port: COM1 INFO : 1/17/2014 3:41:55 PM > Selected model: SGH-I317M INFO : 1/17/2014 3:41:58 PM > Phone was not found on the selected port! INFO : 1/17/2014 3:41:58 PM > Searching for USB diagnostic port... WARN : 1/17/2014 3:41:58 PM > No diagnostic ports found! INFO : 1/17/2014 3:41:58 PM > Connecting to phone on COM6 WARN : 1/17/2014 3:41:58 PM > Phone connection failed INFO : 1/17/2014 3:42:15 PM > ----------------------------------------------------------------------------------- INFO : 1/17/2014 3:42:15 PM > Platform: Samsung Android INFO : 1/17/2014 3:42:15 PM > Selected port: COM135 INFO : 1/17/2014 3:42:15 PM > Selected model: SGH-I317M INFO : 1/17/2014 3:42:17 PM > Phone was not found on the selected port! INFO : 1/17/2014 3:42:17 PM > Searching for USB diagnostic port... WARN : 1/17/2014 3:42:17 PM > No diagnostic ports found! INFO : 1/17/2014 3:42:17 PM > Connecting to phone on COM6 WARN : 1/17/2014 3:42:24 PM > Phone connection failed INFO : 1/17/2014 3:42:26 PM > ----------------------------------------------------------------------------------- INFO : 1/17/2014 3:42:26 PM > Platform: Samsung Android INFO : 1/17/2014 3:42:26 PM > Selected port: COM135 INFO : 1/17/2014 3:42:26 PM > Selected model: SGH-I317M INFO : 1/17/2014 3:42:26 PM > Mode: Normal INFO : 1/17/2014 3:42:26 PM > Phone model: ACEFWMAZ WARN : 1/17/2014 3:42:26 PM > Phone model is not supported INFO : 1/17/2014 3:42:26 PM > Phone was not found on the selected port! INFO : 1/17/2014 3:42:26 PM > Searching for USB diagnostic port... INFO : 1/17/2014 3:42:26 PM > Connecting to phone on COM120 INFO : 1/17/2014 3:42:33 PM > Mode: Emergency Last edited by Octopus box; 01-17-2014 at 14:09. |
01-17-2014, 11:37 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,425 | Hello. Please select COM port manually (COM135), select model SGH-I317M, check (select) "Manual select" option in Software and press "Read info" button. |
01-17-2014, 11:59 | #5 (permalink) |
Member: 1745576 Status: Offline Thanks Meter: 12 | Welcome to Octoplus/Octopus Box Samsung software version 1.4.5 ----------------------------------------------------------------------------------- To connect SGH-I317M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Close window. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HS-USB". 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM135 Selected model: SGH-I317M Mode: Normal Phone model: ACEFWMAZ Phone model is not supported Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM120 Mode: Emergency change atomatcly modle |
01-17-2014, 12:11 | #7 (permalink) |
Member: 1745576 Status: Offline Thanks Meter: 12 | thanks sir my phone is conncted but i repair iemi old iemi is same phone orignle iemi this orignl iemi *******313277 phone same show old iemi Welcome to Octoplus/Octopus Box Samsung software version 1.4.5 ----------------------------------------------------------------------------------- To connect SGH-I317M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Close window. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HS-USB". 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM135 Selected model: SGH-I317M Mode: Normal Phone model: ACEFWMAZ Phone model is not supported Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM120 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM120 Selected model: 707SC Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM120 Phone connection failed Connecting to phone on COM135 Phone connection failed No diagnostic ports found! Connecting to phone on COM6 Phone connection failed ----------------------------------------------------------------------------------- To connect SGH-I317M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Close window. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HS-USB". 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM120 Selected model: SGH-I317M Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM120 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM120 Selected model: SGH-I317M Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM120 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM135 Selected model: SGH-I317M Mode: Normal Phone model: ACEFWMAZ Warning: Selected model (SGH-I317M) differs from the detected one (ACEFWMAZ)! Firmware compiled date: Oct 22 2013 Firmware compiled time: 00:00:00 Firmware released date: Nov 19 2013 Firmware released time: 16:18:09 Phone IMEI: *******031277-4 SW version: M9615ACEHWMAZD179709 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM135 Selected model: SGH-I317M Mode: Normal Phone model: ACEFWMAZ Warning: Selected model (SGH-I317M) differs from the detected one (ACEFWMAZ)! Firmware compiled date: Oct 22 2013 Firmware compiled time: 00:00:00 Firmware released date: Nov 19 2013 Firmware released time: 16:18:09 SW version: M9615ACEHWMAZD179709 Old IMEI: ******031277-4 New IMEI: *****031327-7 IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) i retsrt phone and cheack same |
01-17-2014, 12:20 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,425 | Please always read carefully Software manual before to perform any action. To repair IMEI in this device, You should perform the next steps: 1. Make "Repair EFS". 2. Repair NVM. 3. Connect powered-on phone to PC via Micro USB cable. 4. Enter correct IMEI. 5. Click "IMEI fix" button. 6. Follow software instructions (prompts). |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
01-17-2014, 12:49 | #9 (permalink) |
Member: 1745576 Status: Offline Thanks Meter: 12 | thanks my problam is solved octopus team big helpfull team Warning: Selected model (SGH-I317M) differs from the detected one (ACEFWMAZ)! Firmware compiled date: Oct 22 2013 Firmware compiled time: 00:00:00 Firmware released date: Nov 19 2013 Firmware released time: 16:18:09 SW version: M9615ACEHWMAZD179709 Old IMEI: 004400-15-202000-0 New IMEI: ********31327-7 IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) speal thanks for mr. Octopus box |
