Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 12-11-2014, 00:49   #1 (permalink)
Member: 709917
Thanks Meter: 6
n9005 after flash phone is Bricked
greeting
I have a problem I n9005 flash files I used to suport, but now I have a problem until the end of the phone will not start only Samsung logo appears and immediately restarts. Before that, he had a phone imei Null / Null /. What a way to return the phone to life only to light normally.
Old 12-11-2014, 12:27   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,263
Hello.
What was the firmware version in the phone before exactly? What firmware You have written? Post here full Software log with all of your actions.
Also, try to do the next: make Factory data reset and wipe cache partition, then write different firmwares from the Support Area.
Old 01-04-2015, 15:02   #3 (permalink)
Member: 709917
Thanks Meter: 6
I flash the phone with N9005XXUDMK2_N9005DBTDMK2_DBT_Germany_Nov_13_Andro id_4.3 , after done flash phone is Hardwer Bricked, device is now seen as QDloader 9008. Is there any help?
Old 01-04-2015, 15:05   #4 (permalink)
Member: 709917
Thanks Meter: 6
Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\23-12-2014_15-04-13.log" created (23.12.2014 15:04:17).INFO : 23.12.2014 15:04:18 > Set up system language English (file: English.ini)INFO : 23.12.2014 15:04:18 > Welcome to Octoplus/Octopus Box Samsung software version 1.7.8INFO : 23.12.2014 15:04:18 > -----------------------------------------------------------------------------------INFO : 23.12.2014 15:04:18 > To connect SM-N9005 phone you have to perform the following steps:
INFO : 23.12.2014 15:04:18 > 1. Disconnect USB cable from phone.
INFO : 23.12.2014 15:04:18 > 2. Go to Menu->Settings->More->About Device.
INFO : 23.12.2014 15:04:18 > 3.Tap on "Build number" 7 times to enable developer options.
INFO : 23.12.2014 15:04:18 > 4. Go to Menu->Settings->More->Developer options.
INFO : 23.12.2014 15:04:18 > 5. Turn on "USB Debugging" option.
INFO : 23.12.2014 15:04:18 > 6. Go to dial window.
INFO : 23.12.2014 15:04:18 > 7. Enter "*#0808#" number.
INFO : 23.12.2014 15:04:18 > 8. Select "DM+Modem+ADB".
INFO : 23.12.2014 15:04:18 > 9. Press Home button.
INFO : 23.12.2014 15:04:18 > 10. Go to dial window.
INFO : 23.12.2014 15:04:18 > 11. Enter "*#9090#" number.
INFO : 23.12.2014 15:04:18 > 12. Set "Diag config" to "USB" value.
INFO : 23.12.2014 15:04:18 > 13. Restart phone.
INFO : 23.12.2014 15:04:18 > 14. Press "Read Info" in software.INFO : 23.12.2014 15:04:37 > Selected firmware file: N9005XXUDMK2_N9005DBTDMK2_DBT_Germany_Nov_13_Andro id_4.3.octWARN : 23.12.2014 15:04:39 > Please put the phone into Download Mode and connect USB cable.WARN : 23.12.2014 15:04:39 > To put SM-N9005 into Download Mode, You have to perform the following steps:
WARN : 23.12.2014 15:04:39 > 1. Reconnect the battery.
WARN : 23.12.2014 15:04:39 > 2. Press and hold "Volume-" + "Home" + "Power ON" keys.
WARN : 23.12.2014 15:04:39 > 3. When phone turns on, press "Volume+" key.INFO : 23.12.2014 15:04:39 > Found phone on INFO : 23.12.2014 15:04:39 > Firmware write started.INFO : 23.12.2014 15:04:39 > Writing SBL1 section...INFO : 23.12.2014 15:04:42 > SBL1 section has been written successfully.INFO : 23.12.2014 15:04:42 > Writing ABOOT section...INFO : 23.12.2014 15:05:29 > ABOOT section has been written successfully.INFO : 23.12.2014 15:05:29 > Writing RPM section...INFO : 23.12.2014 15:05:31 > RPM section has been written successfully.INFO : 23.12.2014 15:05:31 > Writing TZ section...INFO : 23.12.2014 15:05:34 > TZ section has been written successfully.INFO : 23.12.2014 15:05:34 > Writing DBI section...INFO : 23.12.2014 15:05:36 > DBI section has been written successfully.INFO : 23.12.2014 15:05:36 > Writing APNHLOS section...INFO : 23.12.2014 15:05:38 > APNHLOS section has been written successfully.INFO : 23.12.2014 15:05:38 > Writing BOOT section...INFO : 23.12.2014 15:05:42 > BOOT section has been written successfully.INFO : 23.12.2014 15:05:42 > Writing RECOVERY section...INFO : 23.12.2014 15:05:46 > RECOVERY section has been written successfully.INFO : 23.12.2014 15:05:47 > Writing SYSTEM section...INFO : 23.12.2014 15:11:52 > SYSTEM section has been written successfully.INFO : 23.12.2014 15:11:52 > Writing MODEM section...INFO : 23.12.2014 15:12:03 > MODEM section has been written successfully.INFO : 23.12.2014 15:12:03 > Writing CACHE section...INFO : 23.12.2014 15:12:09 > CACHE section has been written successfully.INFO : 23.12.2014 15:12:09 > Writing HIDDEN section...INFO : 23.12.2014 15:12:22 > HIDDEN section has been written successfully.INFO : 23.12.2014 15:12:23 > Firmware writing successfully completed.
Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\23-12-2014_15-04-13.log" closed (23.12.2014 15:23:13).
Old 01-04-2015, 15:14   #5 (permalink)
Member: 1146942
Sonork: 100.1587278
Currently we have no solution, how to repair such device.
Old 01-04-2015, 16:28   #6 (permalink)
Member: 2093517
Thanks Meter: 25
tell me on skype i will help you to unbrick it my skype id : anti.system1
Page generated in 0.13261 seconds with 8 queries
